Original springs, green paint |
914Next |
Feb 11 2016, 01:44 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Had the original springs replaced pn my '73 2.0 a few weeks ago due to rear end sag. Finally got around to picking up the originals from Checkpoint Auto. Wanted to keep them since the car is so original.
Was really surprised at the fact that they are in such excellent condition. Also noticed as I was looking at them that there appears to be some green paint on them. The car was undercoated and it looks like there is some undercoating on the spring but green paint underneath? Anyone know what that is? Thanks. |
Tom_T |
Feb 11 2016, 08:27 PM
Steve,
That was to ID that they were the 90# OE springs for the 2.0s, as used at the factory so that Hans & Fritz hopefully got the right ones on the correct car! However, my 88 Westy also had painted-dab codes on it's springs from the factory, & in 2012 for the rolling resto when my mechanic changed out its OE springs we found that they'd put in the wrong "normal duty" springs for the non-camper Westy (i.e.: tin-top Vanagon springs) on the driver's side & correct HD Westy springs on the passenger side - explaining an odd "Lean" it had since new & which the original dealer claimed was normal & not a problems (a-holes! (IMG:style_emoticons/default/mad.gif) ). If you look at the pix of Steve G's/smg Sahara Beige 73 2L in the O&H Forum's nailed thread called "The few, the rare..." you can see similar markings there. Also, Jeff Bowlsby's website has many of the factory marings at this link: http://bowlsby.net/914/Classic/PLM.htm Cheers! Tom /////// |
JeffBowlsby |
Feb 12 2016, 02:07 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have never found good photos of those spring paint dabs. This from the factory WSM
914Next |
Feb 12 2016, 08:16 PM
Peashooter |
Apr 17 2016, 07:38 PM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
Interesting. I had two sets of springs for my 914-6, one set had two yellow stripes, one set three yellow stripes. Wondered what they meant. Probably similar to the green paints.
Lo-Fi Version | Time is now: 5th May 2024 - 11:20 PM |
