Side shift bushing issue, Has anyone else run into this? |
-JR- |
Feb 12 2016, 02:08 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I'm in the process of cleaning up a few things on my 75 teen.
One of the jobs was to fix up a sloppy tail shift bushing, THIS ONE. (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.914rubber.com-2055-1455307717.1.jpeg) I purchased a new one from my friends at AutoAtlanta. They inform me I did in fact order the correct one. When I installed this bushing into my side shifter housing it fits loose both on the trans and the shift rod. I've inspected the opening for signs of wear, but it looks to be in good shape and not worn, plus the old bushing did fit tight in the hole. Measuring the transmission opening I get 22mm but the bushing is just a hair under 21mm. I've been advised that I must have had a custom bushing installed. My car is very original and the bushing I cut out looked very old. The bushing I removed looked more like the FIREWALL BUSHING with no "castle" like fingers, it was just one solid ring. Anyone have an idea what I'm running into? |
brant |
Feb 12 2016, 02:31 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
your running into the last owners custom bushing...
make it from oil impregnated brass make it custom to fit the wear in your shift rod, and wear in your transmission shift console. |
ChrisFoley |
Feb 12 2016, 02:53 PM
I am Tangerine Racing Group: Members Posts: 7,910 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Just JB weld the new bushing in place so it doesn't move around.
-JR- |
Feb 12 2016, 05:47 PM
Anyone know the bushing dimensions for the firewall bushing...
914-424-224-03 I'm taking a guess that this one might be what was installed in the transmission. thanks! -JR- |
bretth |
Feb 12 2016, 06:25 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
The subject of the post is side shift bushing but in your post you call it a tail shift bushing. Maybe is the wrong one? 75 is side shift of course though i haven't even taken mine apart yet.
Brett |
Mikey914 |
Feb 12 2016, 08:42 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This what you are looking for? It's part # 914.424.224.02
AT $2.99!!! http://shop.914rubber.com/Late-side-shifte...m?categoryId=-1 Attached thumbnail(s) |
r_towle |
Feb 12 2016, 09:23 PM
Custom Member Group: Members Posts: 24,567 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
They all fit loose.
I made custom bronze ones for mine that are tight. Plastic ones don't fit |
larryM |
Feb 12 2016, 10:15 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
-JR- |
Feb 13 2016, 12:06 AM
This what you are looking for? It's part # 914.424.224.02 AT $2.99!!! http://shop.914rubber.com/Late-side-shifte...m?categoryId=-1 Thanks! Not sure if you noticed but I stole the parts diagram picture from your site to use at the top of this post! That's the part number I have. If you have one on hand, could I persuade you to measure the transmission hole size it needs? I'm talking about the outer captured area and not the inner diameter, if that makes sense. I still can't believe my trans was worn so bad that someone machined out the opening larger. The car is a garage kept 60K mile unit. I find it much easier to believe the Chinese replacement is just a poor copy. Thanks again. BTW - Love your site, lots of goodies I need there, but until the Canadian peso improves I'm going to hold off. -JR- |
Larmo63 |
Feb 13 2016, 12:41 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Use the common (eBay) bronze one in the rear console, and use the Tangerine bushing at the firewall.
Easy peasy. |
cary |
Feb 13 2016, 09:02 AM
What Lawrence said.
That's the arrangement that I have on my white car. http://www.gprparts.com/ShopforOEAccesorie...ALL&mode=PA |
Dave_Darling |
Feb 13 2016, 11:06 AM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The hole in the flange wears larger over the years. It's an interesting solution to machine it larger and use a different bushing, but it doesn't sound like it was working all that well.
The rod also wears and gets a "neck" in it, which can make for more slop. The fix for that involves either building up the rod with weld and machining or filing it down, or machining it down and putting a sleeve on it. --DD |
-JR- |
Feb 13 2016, 12:00 PM
Use the common (eBay) bronze one in the rear console, and use the Tangerine bushing at the firewall. Easy peasy. Love that setup, but that bushing apparently won't fit my Trans. Once I've confirmed my Trans has been machined, then I'd prefer a custom bushing in place of gluing one in. Thanks! |
TheCabinetmaker |
Feb 13 2016, 04:25 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The shift console most likely has not been machined. Most of them are a little bigger that they were new. Especially if it's been greasy at one time. Grease and dirt combined equal a sanding medium.
-JR- |
Feb 14 2016, 10:16 PM
The shift console most likely has not been machined. Most of them are a little bigger that they were new. Especially if it's been greasy at one time. Grease and dirt combined equal a sanding medium. I get that, but my old bushing fit tight. So tight that the surfaces were clean when I removed it. Once I have a second opinion on the bushing or transmission hole size, then I'll move forward. Thanks! |
porschetub |
Feb 14 2016, 11:55 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
-JR- |
Feb 18 2016, 12:29 AM
Got my digital caliper running.
The first bushing I tried, non-OEM, measured up with a console hole diameter of 20.22-20.30mm. Digging around my boxes for another part I stumbled on a OEM Porsche bushing I must have bought a few years back. PN 914-424-224-02 It measures 20.85mm outside diameter. That's .5m larger for the Porsche one. It fits much better on my console but unfortunately it's still not good enough for me. My console hole measures up at 21.3mm diameter. Almost big enough for the Patrick bushing. Might just order that one up and be done with it until I put my Vellios 915 transmission in. -JR- |
Lo-Fi Version | Time is now: 27th April 2024 - 05:00 PM |
