Side shift bushing issue, Has anyone else run into this? |
-JR- |
Feb 12 2016, 02:08 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I'm in the process of cleaning up a few things on my 75 teen.
One of the jobs was to fix up a sloppy tail shift bushing, THIS ONE. (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.914rubber.com-2055-1455307717.1.jpeg) I purchased a new one from my friends at AutoAtlanta. They inform me I did in fact order the correct one. When I installed this bushing into my side shifter housing it fits loose both on the trans and the shift rod. I've inspected the opening for signs of wear, but it looks to be in good shape and not worn, plus the old bushing did fit tight in the hole. Measuring the transmission opening I get 22mm but the bushing is just a hair under 21mm. I've been advised that I must have had a custom bushing installed. My car is very original and the bushing I cut out looked very old. The bushing I removed looked more like the FIREWALL BUSHING with no "castle" like fingers, it was just one solid ring. Anyone have an idea what I'm running into? |
Larmo63 |
Feb 13 2016, 12:41 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Use the common (eBay) bronze one in the rear console, and use the Tangerine bushing at the firewall.
Easy peasy. |
-JR- |
Feb 13 2016, 12:00 PM
Use the common (eBay) bronze one in the rear console, and use the Tangerine bushing at the firewall. Easy peasy. Love that setup, but that bushing apparently won't fit my Trans. Once I've confirmed my Trans has been machined, then I'd prefer a custom bushing in place of gluing one in. Thanks! |
Lo-Fi Version | Time is now: 11th May 2024 - 09:47 PM |
