> Correct main jet for Weber dual 40's
motomoss
post Feb 15 2016, 12:34 PM
Hello, I currently have 1974 2.0 and am thinking on purchasing a big bore kit for it. I have a set of Weber dual 40's and distributor set up for carbs that I will be using on the car but do not know the correct main jet size for the carbs (IMG:style_emoticons/default/confused24.gif) . Any help would be much appreciated.
Starlack
post Feb 15 2016, 01:22 PM
QUOTE(motomoss @ Feb 15 2016, 10:34 AM) *
Hello
I have documents from a German engine builder.
Porsche 914
Venturies 30mm
Mixing tube F11
Main Jet 125
Idling jet 55
Regulating nozzle 180 evtl.200
hope to have helped
Elliot Cannon
post Feb 15 2016, 05:45 PM
Group: Retired Members
QUOTE(Starlack @ Feb 15 2016, 11:22 AM) *
Hello
Porsche 914
Venturies 30mm
Mixing tube F11
Main Jet 125
Idling jet 55
hope to have helped
This might be a good place to start but depending on engine size you might have to do a little experimenting with jet combinations
jmill
post Feb 15 2016, 06:29 PM
Green Hornet
It's an air correction jet instead of a regulating nozzle here in the States. Buy the weber tech manual by Bob Tomlinson. Read it until you understand how the carb works. I had to read it several times before i wrapped my head around all of it.
You'll need to buy a carb cam too. Otherwise you won't be pleased with the performance.
- Lo-Fi Version Time is now: 30th July 2025 - 03:40 PM
