having a intermittent fuel pump issue ( the ghost ), should i do something about it or not |
thelogo |
Feb 15 2016, 06:50 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Drove the 9 one 4
About 20 miles ,parked once engine off for two minutes, fired up drove 3 blocks Park engine then off for 15 mins When i go to start it no fuel pump sound or fuel getting to the engine .............. Called for the tow waited 35 mins ,still no tow truck ,i try the fuel pump again and suddenly It works and car runs great . Drove the car again next day runs fine ,now Was it the x- file phenomenon of vaper lock Or am i way off (IMG:style_emoticons/default/smoke.gif) |
Mike Bellis |
Feb 15 2016, 06:55 PM
Try a new relay first. You might have an original 40 year old relay in there. I've had more than one fuel pump problem traced to bad relays.
dlee6204 |
Feb 15 2016, 07:12 PM
I'd also check the fuse and rotate it in its holder. That has worked for me several times
thelogo |
Feb 15 2016, 07:47 PM
I'd also check the fuse and rotate it in its holder. That has worked for me several times Can you be more specific As in where is the fuse (IMG:style_emoticons/default/flag.gif) |
boxsterfan |
Feb 15 2016, 08:00 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Worth it to check the relay and the fuses. I did this for mine, but in the end it was the fuel pump gone dead. My car ended up like this due to the "while I am in there" bug:
Attached thumbnail(s) |
Feb 15 2016, 08:17 PM
One of the two on the relay board. --DD |
ConeDodger |
Feb 15 2016, 08:31 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Mine did this. Ultimately, had to replace it. (IMG:style_emoticons/default/blink.gif)
Bartlett 914 |
Feb 16 2016, 02:30 PM
I had similar problems. Mine was the relay board itself causing the intermittent problem
saigon71 |
Feb 16 2016, 02:47 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Check the relays & fuses first as suggested.
Then check the wiring at the pump to make sure the connections are tight. |
thelogo |
Feb 18 2016, 09:02 PM
It has continued to start reliably
So i think im going to ignore until my next oil change An value adjustment An pray it dont leave me stranded (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:45 PM |
