The "RIGHT" place to mount the hood emblem. |
CptTripps |
Mar 21 2005, 11:36 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
MY car came withthe emblem mounted WAY too high. Is there a 'correct' measurement for it?
I've seen a few higher than others, but mine was just way too far into the hood for it's own good. (IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/0.jpg) |
ArtechnikA |
Mar 21 2005, 11:38 AM
with the possible exception of Dr Porsche's personal 8-cyl 914, 100% of them were installed in the aftermarket.
put it where you like. |
Joe Bob |
Mar 21 2005, 11:40 AM
I remove all mine...but typically about 4 inches up from the edge.
Also, glue or tape it on...some little bastrad WILL try to steal it and if it held on with speed nuts it's gonna screw up yer hood when he pries it off with a screwdriver.... |
bondo |
Mar 21 2005, 11:46 AM
The correct place to mount it is in your glove box (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
If you insist on putting it on your hood, grind off the pegs and use a good foam double stick tape, so the rust monster doesn't get you. |
McMark |
Mar 21 2005, 12:07 PM
In the trash. Yeah, don't drill your hoood. That way when you decide you actually don't like the emblem you can take it off. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
I draw a line between the tops of the headlights and mount it centered between the front edge of the hood and that line. |
Rockaria |
Mar 21 2005, 12:37 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
The best thing to do is make a 1:1 scale scan and color printout of it on paper. Cut it out and put a little tape on it and move it around till you like where it is. Then its easy to drill and install.
Everyone is a bit different on the pacement I have found. |
CptTripps |
Mar 21 2005, 12:45 PM
I think I'll put it on because I like it, but thanks for the tip on using tape! I hadn't hought of that angle.
Tom73 |
Mar 21 2005, 12:50 PM
Member Group: Members Posts: 180 Joined: 20-September 04 From: Central Texas Member No.: 2,792 |
I taped off the center of the hood, drew a center line and then moved the emblem up and down that line until I hit a spot that looked right. Was about half way between the top of the lights and the bottom of the hood.
tom... |
Mar 21 2005, 01:06 PM
Resident German Group: Admin Posts: 41,661 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yepp, on the shelf together with your other porsche Memorabilia ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy <---- ducking for cover ... |
rick 918-S |
Mar 21 2005, 01:09 PM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
There is no correct measurement for it as you are not installed at the factory. I would mount it on a plaque and hang it in the garage on the wall.
Scott S |
Mar 21 2005, 01:10 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
here is how I measure them....
Scott S |
Mar 21 2005, 01:11 PM
mine.
CptTripps |
Mar 21 2005, 01:20 PM
Ahhh....I see. Thanks...great tip. |
rhodyguy |
Mar 21 2005, 01:40 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
he already has holes. so a bit less than 1/2 a badge length is all you get. drilling 2 more holes for what will probably be -1 3/8" is more trouble than it's worth. if the pins are up and down as opposed to side to side you will be moving it less. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) spring for a new base seal and live with it.
GWN7 |
Mar 21 2005, 03:59 PM
Actually the badges were factory instaled, but only if you had a 918 (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (only on one of them)
Scott S |
Mar 21 2005, 04:11 PM
Hmmmm.... pretty darn close!
airsix |
Mar 21 2005, 04:28 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
I don't know what's up with all the poo-pooing. What's wrong with a badge? I think they look nice. Better a badge than those hideous "Look at me! Look at me!" Porsche script side-stripes. I think a badge is subtle and tasteful.
But who am I to talk. I'd NEVER change my car from stock (turbo). I mean, our cars sould be left exactly as they came from the factory (aftermarket EFI). It's just not right to deviate from original (5-lug). Isn't it good enough the way it was (custom flares). We should be satisfied and leave well-enough alone (big brakes, hydraulic clutch, 16x8" wheels, relocated fuel pump, relocated battery, aftermarket seats...) (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) -Ben M. |
Series9 |
Mar 21 2005, 04:47 PM
Here's mine:
Mar 21 2005, 06:08 PM
except, the car in your pic is not a 918, nor is the badge on that car permanent (just taped on) ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
MarkG |
Mar 21 2005, 06:11 PM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
That is EXACTLY what happened on my 308.....only Ferrari BOLTS their hood emblems on, so after breaking his screwdriver trying to get the hood emblem off, the a$$hole ran the broken screwdriver across the hood a few times..... $150 for new hood emblem.....we wont discuss the $$$ to fix the rest.... |
Lo-Fi Version | Time is now: 28th May 2024 - 07:34 PM |
