WTB: 914-6 Wiper Motor (non-working), I need the harness |
gcrotvik |
Feb 17 2016, 03:20 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I am hoping to find an old, non-working 914-6 wiper motor. I need the harness from it.
Thanks! Greg |
914Sixer |
Feb 17 2016, 04:22 PM
Jeff B might be able to make you one. I THINK it uses the same end as the headlight motor BUT not positive.
gcrotvik |
Feb 17 2016, 05:02 PM
Jeff B might be able to make you one. I THINK it uses the same end as the headlight motor BUT not positive. Hi Mark, Yes, the plug that goes through the inner front crush panel and connects to the wiper switch is similar to the headlight relay terminal but the harness also has the wires going to the ground strap and the washer motor as well. I was hoping to find one. The wiper motor I have is missing the harness. Thanks! Greg |
Lo-Fi Version | Time is now: 17th May 2024 - 04:42 PM |
