QUOTE(914Sixer @ Feb 17 2016, 02:22 PM)
Jeff B might be able to make you one. I THINK it uses the same end as the headlight motor BUT not positive.
Hi Mark,
Yes, the plug that goes through the inner front crush panel and connects to the wiper switch is similar to the headlight relay terminal but the harness also has the wires going to the ground strap and the washer motor as well. I was hoping to find one. The wiper motor I have is missing the harness.
Thanks!
Greg
