Oil Pressure Sender |
Amphicar770 |
Feb 18 2016, 11:20 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
This seems like a noob question but ...
There is what I assume is an oil pressure sending switch on top of engine near the oil cooler. I was going to replace this when I do the oil cooler but can not seem to find part number or even a diagram showing it. Looks like there is a similar unit at the taco plate that shows up in a lot of places. Any guidance in what part to order? Thanks |
stugray |
Feb 18 2016, 11:35 PM
McMark |
Feb 19 2016, 08:17 AM
The one in the taco plate is temperature.
http://www.amazon.com/Porsche-Pressure-War...g/dp/B00CGALC5E |
toadman |
Feb 19 2016, 10:15 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
Autoatlanta has a great set of hard parts diagrams for the 914-4 and the 914-6 on their website. I looked there and found the part number for the 914-4 oil pressure sensor is 021919081D. You should confirm this before you order the part.
stugray |
Feb 19 2016, 10:32 PM
The link I posted above is the single most important item to have if you work on a 914.
Page 53 items 26 & 27 26 - 021 919 081 D oil pressure switch http://www.pelicanparts.com/More_Info/0219...1-919-081-D-OEM 27 - 039 919 268 sender http://www.pelicanparts.com/More_Info/0399...039-919-268-OEM |
Lo-Fi Version | Time is now: 17th May 2024 - 06:45 PM |
