Amphicar770
Feb 18 2016, 11:20 PM
This seems like a noob question but ...
There is what I assume is an oil pressure sending switch on top of engine near the oil cooler.
I was going to replace this when I do the oil cooler but can not seem to find part number or even a diagram showing it. Looks like there is a similar unit at the taco plate that shows up in a lot of places.
Any guidance in what part to order?
Thanks
McMark
Feb 19 2016, 08:17 AM
toadman
Feb 19 2016, 10:15 PM
Autoatlanta has a great set of hard parts diagrams for the 914-4 and the 914-6 on their website. I looked there and found the part number for the 914-4 oil pressure sensor is 021919081D. You should confirm this before you order the part.
stugray
Feb 19 2016, 10:32 PM
The link I posted above is the single most important item to have if you work on a 914.
Page 53 items 26 & 27
26 - 021 919 081 D oil pressure switch
http://www.pelicanparts.com/More_Info/0219...1-919-081-D-OEM27 - 039 919 268 sender
http://www.pelicanparts.com/More_Info/0399...039-919-268-OEM
