Getting rid of the sail panel vynal, How do you make the trim fit good after? |
jgiroux67 |
Mar 21 2005, 07:47 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
How do you make the trim on the sail panel fit good after you take the vynal off? It seems loose now and has a small gap between the body and the trim pieces. Any suggestion on how to get rid of the problem?
Porsche Rescue |
Mar 21 2005, 08:28 PM
I think you just live with the gap. It should fit about the same. Vinyl is not very thick. The factory cars with body colored sails came with the trim pieces also body color. What ever gap there was did not show.
You will have three holes to fill at the bottom unless you leave the trim there. |
jgiroux67 |
Mar 21 2005, 08:33 PM
I already fillid in the holes so I cant go back now, oh well I'm not much of a fan of the two tone look with the targa. I'm gonna have the trim pieces in black and the car is gonna be blue so I guess it won't show too much.
Rick_Eberle |
Mar 21 2005, 11:58 PM
Member Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 |
I got out the Dremel, and made the holes oval shaped on the strips that go across the top of the sail. Mine are new, and have double sided tape from the factory as well as the screws.
Lo-Fi Version | Time is now: 19th May 2024 - 09:42 AM |
