914 TURBO CARRERA UPDATE 3/21/05, intercooler install |
iamchappy |
Mar 21 2005, 08:28 PM
It's starting to come together, I have been busy fashioning the intercooler and will begin the duct work for the exit air out of the intercooler, I will be pulling the air through the intercooler via 2-7"electric fans and the exit air will be ducted through and past my transmission cooler and out behind the rear bumper. the fresh air will be coming in through a duct in my rear spoiler, I should have it all done in a few days. look at the pictures, the fans will be mounted underneth the IC, I placed them on top so you have an idea of the size of the IC.
iamchappy |
Mar 21 2005, 08:29 PM
2
Qarl |
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Make your pics bigger
800x600 at least! |
iamchappy |
3
iamchappy |
Mar 21 2005, 08:30 PM
4
Qarl |
Mar 21 2005, 08:32 PM
Your pics are the size of my penis after I got the Elise... very tiny!
iamchappy |
Mar 21 2005, 08:33 PM
4
iamchappy |
Mar 21 2005, 08:34 PM
There getting bigger.
iamchappy |
Mar 21 2005, 08:35 PM
I was going to composite them but got lazy.
Do you really want bigger pictures reposted? |
Qarl |
Mar 21 2005, 08:48 PM
Yes... you can edit the post and reattach a larger version
iamchappy |
Mar 21 2005, 08:49 PM
I will do it later have to go pick up the kid.
Brando |
Mar 21 2005, 09:33 PM
In that thing? Fckin lucky kid!
redshift |
Mar 21 2005, 09:36 PM
Wow man... that is insane!(ly small!)
M |
iamchappy |
Mar 24 2005, 09:38 PM
I have been busy, I am getting very close to getting this thing on the road. I still have the transmission cooler and pump to mount, then I am pretty much done. Just a little more work on the venting of the exit air out through and around the transmission cooler which will be mounted back behind the bumper area, I am shielding off the muffler with stainless steel to reflect the heat away from where I am mounting it. More pictures still to come.
iamchappy |
Mar 24 2005, 09:39 PM
2...
iamchappy |
Mar 24 2005, 09:40 PM
3....
iamchappy |
4.....
Qarl |
Mar 24 2005, 09:46 PM
Why the plate with the holes for the fans?
You're partly blocking the air flow through the rest of the intercooler. |
iamchappy |
Mar 24 2005, 09:50 PM
I works like a shroud so it pulls over the entire surface area of the intercooler otherwise the fans would only pull through the surface area they cover.
Mueller |
Mar 24 2005, 09:51 PM
damn...nice work (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) ...I'm never showing pictures of my car here again (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Lo-Fi Version | Time is now: 9th May 2024 - 03:25 PM |
