iamchappy
Mar 21 2005, 08:28 PM
It's starting to come together, I have been busy fashioning the intercooler and will begin the duct work for the exit air out of the intercooler, I will be pulling the air through the intercooler via 2-7"electric fans and the exit air will be ducted through and past my transmission cooler and out behind the rear bumper. the fresh air will be coming in through a duct in my rear spoiler, I should have it all done in a few days. look at the pictures, the fans will be mounted underneth the IC, I placed them on top so you have an idea of the size of the IC.
iamchappy
Mar 21 2005, 08:29 PM
2
Qarl
Make your pics bigger
800x600 at least!
iamchappy
3
iamchappy
Mar 21 2005, 08:30 PM
4
Qarl
Mar 21 2005, 08:32 PM
Your pics are the size of my penis after I got the Elise... very tiny!
iamchappy
Mar 21 2005, 08:33 PM
4
iamchappy
Mar 21 2005, 08:34 PM
There getting bigger.
iamchappy
Mar 21 2005, 08:35 PM
I was going to composite them but got lazy.
Do you really want bigger pictures reposted?
Qarl
Mar 21 2005, 08:48 PM
Yes... you can edit the post and reattach a larger version
iamchappy
Mar 21 2005, 08:49 PM
I will do it later have to go pick up the kid.
Brando
Mar 21 2005, 09:33 PM
In that thing? Fckin lucky kid!
redshift
Mar 21 2005, 09:36 PM
Wow man... that is insane!(ly small!)
M
iamchappy
Mar 24 2005, 09:38 PM
I have been busy, I am getting very close to getting this thing on the road. I still have the transmission cooler and pump to mount, then I am pretty much done. Just a little more work on the venting of the exit air out through and around the transmission cooler which will be mounted back behind the bumper area, I am shielding off the muffler with stainless steel to reflect the heat away from where I am mounting it. More pictures still to come.
iamchappy
Mar 24 2005, 09:39 PM
2...
iamchappy
Mar 24 2005, 09:40 PM
3....
iamchappy
4.....
Qarl
Mar 24 2005, 09:46 PM
Why the plate with the holes for the fans?
You're partly blocking the air flow through the rest of the intercooler.
iamchappy
Mar 24 2005, 09:50 PM
I works like a shroud so it pulls over the entire surface area of the intercooler otherwise the fans would only pull through the surface area they cover.
Mueller
Mar 24 2005, 09:51 PM
damn...nice work
...I'm never showing pictures of my car here again
iamchappy
Mar 24 2005, 09:55 PM
Qarl, you cant see the depth between the intercooler and the plate with the fans very well in the pictures, it passed the suck the plastic bag to the top of the intercooler test very well.
MecGen
Mar 24 2005, 10:00 PM
Amazing concept...
I hope you get flying real soon..
cheers
joe
iamchappy
Mar 24 2005, 10:02 PM
I talked to the dyno guys the other day and plan to get it up to them to dial it in with there wide band AR and get the boost retard set right. I think the car may obtain scary fast if I get it up to around 400HP but the safe boost level will determine that, I may need to add another injector if the 7th one I have now falls short of enrichment. maybe set an 8th injector to fire at 10lbs. I cant wait to find out.
Qarl
Mar 24 2005, 10:05 PM
Okay... I didn't realize there was a space between the bottom of the intercooler and the plate.
I can see it a little better now that you have bigger pictures!
iamchappy
Mar 24 2005, 10:09 PM
red914
Mar 24 2005, 10:27 PM
you may get 400 horsepower, but you can't put the targa top in the trunk anymore. betcha didn't think of that, now did you!
my jealousy is making my stomach hurt.
i am going to go look at my car in the garage, on jack stands, with a big puddle of oil under it. i hope you are happy.
Maltese Falcon
Mar 24 2005, 11:27 PM
Chappy, did you calc the CFM rate thru this IC unit ? It's a Spearco from Turbonetics , yes ? It looks somewhat borderline flow for the 3.0 ...the fans should help cool everything thru. Remember...too small an intercooler= big pressure drop in boost, you may loose 2 to 3 psi.
Hopefully not the case.
Marty
iamchappy
Mar 25 2005, 07:31 AM
Marty, yes spearco core 1080 CFM good to 800hp made to be used on Grand Nationals.
maf914
Mar 25 2005, 07:51 AM
QUOTE (iamchappy @ Mar 24 2005, 07:50 PM) |
I works like a shroud so it pulls over the entire surface area of the intercooler otherwise the fans would only pull through the surface area they cover. |
Also without the shroud you would get short circuiting of the airflow around the end tips of the fan blades. Shrouds can really increase the efficiency when fans are used.
That is a fancy battery hold down you have there. Is that one of the bling-bling Optima billet thingies?
iamchappy
Mar 25 2005, 09:24 AM
Ebay optima battery box buy, looks Bling, Bling, but very functional.
The intercooler is 3.5" thick with a surface area of 6 x 18, it uses a Spearco core from Turbotronics. flows up to 1080 cfm's so they say. I will have to crank it up to see how it works
, it sure looks cool in the trunk, I cant help it I am becoming obsessive over the install, one thing seems to lead into another
, I am fabricating up aluminum piping to replace the silicone hose now, and installing the transmission cooler.
Root_Werks
Mar 25 2005, 09:57 AM
Truly amazing! Maybe someday I can stuff a 3.0 turbo in my six!
Very inspiring!
