LS3 Oil pan |
LS3 Oil pan |
partwerks |
Feb 21 2016, 08:33 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I don't know. According to the mechanic, there are 3 depths of oil pans for the LS3 w/480 horse, and we have on the shortest, which still is about 1 1/2" below the engine bar from Renegade. He was going to research on what else would work that would be no lower than the engine bar.
Any thoughts, ideas, or suggestions? Otherwise, the engine is basically in, and hooked up to the Boxster trans. |
Feb 21 2016, 09:50 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You could pull the pan and measure the clearances for the crankshaft and sump to see what you could do to make the pan shorter, and you could also consider a dry sump if you are still concerned.
JRust |
Feb 21 2016, 10:09 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
If this is a renegade cradle. Which locks like it was cut & modified as it sits. Why was it changed. I mean this is made for the LS motor right? So why was it cut & changed. They have to take all the LS things into account. Do they use a custom oil pan to make it work? Something isn't right with that setup? Is the motor supposed to sit a little higher so the pan isn't a problem? Hopefully Bob Bigkat will chime in or Cracker as they both have LS setups
partwerks |
Feb 22 2016, 07:43 AM
Not sure, but when I looked in there, I don't see how it could be up higher, as it is close to the back, where the front of the trunk is.
bulitt |
Feb 22 2016, 10:32 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Send Tony "Cracker" a PM. Think he has a handle on the LS3 stuff.
http://www.914world.com/bbs2/index.php?sho...263639&st=0 |
waldo |
Feb 22 2016, 01:44 PM
Newbie Group: Members Posts: 4 Joined: 7-May 05 From: Lake Goodwin Wa. Member No.: 4,037 |
some info on oil pans. http://nookandtranny.com/Info_LSx.html
DBCooper |
Feb 22 2016, 05:26 PM
That's a pretty nice summary of the LS motors, what's the same and how they're different. Thanks. |
1stworks |
Feb 23 2016, 09:37 AM
Member Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
been there..
Cracked a camaro oil pan. The only pan to use on any ls is Corvette bat wing Oil pan. Fit perfect. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1456241870.1.jpg) |
1stworks |
Feb 23 2016, 10:03 AM
here's the camaro pan,it drops down below engine mounting bar.
Not ideal but works.... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1456243410.1.jpg) Here's hitting it on rail road track..... https://www.youtube.com/watch?v=vvG7cnz4aCA |
partwerks |
Feb 23 2016, 10:40 PM
I got some more info from another 914 LS owner: http://www.lsenginediy.com/ls-swaps-oil-pan-guide/
1stworks |
Feb 24 2016, 08:13 AM
Lo-Fi Version | Time is now: 21st May 2024 - 03:41 PM |
