Fresh Air Blower Light |
lsintampa |
Feb 22 2016, 10:09 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
So I removed my entire dash - frame included and now I'm in the throws of putting it all back in.
I was fairly careful to label all wires, lights, etc. with masking tape - so putting it back together wouldn't be much of an effort. However - I have one situation that I'm perplexed about (so far) that involves the heater control levers. There is a fresh air blower light on the right bottom of the assembly that I thought should only light when there is power to the blower motor. Mine lights all the time - regardless of the blower motor switch position. There is a brown ground wire that comes off of the assembly that connects to the wire harness, then there is a brown ground wire that when I ground it will light up that blower light. The motor blows fine - low, medium, high - depending on the lever position. The issue is that the light is always on - regardless of the lever position. UGH Thanks for any thoughts. Len |
Lo-Fi Version | Time is now: 18th May 2024 - 02:29 AM |
