So I removed my entire dash - frame included and now I'm in the throws of putting it all back in.
I was fairly careful to label all wires, lights, etc. with masking tape - so putting it back together wouldn't be much of an effort.
However - I have one situation that I'm perplexed about (so far) that involves the heater control levers. There is a fresh air blower light on the right bottom of the assembly that I thought should only light when there is power to the blower motor.
Mine lights all the time - regardless of the blower motor switch position.
There is a brown ground wire that comes off of the assembly that connects to the wire harness, then there is a brown ground wire that when I ground it will light up that blower light.
The motor blows fine - low, medium, high - depending on the lever position. The issue is that the light is always on - regardless of the lever position.
UGH
Thanks for any thoughts.
Len
