Grounding Tab Locations, I always forget about this one |
76-914 |
Feb 24 2016, 09:47 AM
When I re-installed the fuel tank in Whitey I saw this looking at me. As often as this subject comes up I had completely forgotten about this ground tab. Only on the 75-76 models with the front located fuel pump. And by next week I will have probably forgotten again. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/slits.gif)
Andyrew |
Feb 24 2016, 10:00 AM
Guess I've never looked inside a 75-76 fuel tank area as I've never seen that ground strap!
ndfrigi |
Feb 24 2016, 10:38 AM
My 75 1.8 has that ground too for the fuel pump.
74ravenna |
Feb 24 2016, 11:06 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
Is there a list of all the ground locations?
Thanks |
76-914 |
Feb 24 2016, 11:16 AM
I think they're listed on Bowsley's website.
Tom_T |
Feb 24 2016, 01:57 PM
And by next week I will have probably forgotten again. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/slits.gif) I hear ya on that one Kent! I just write it off as Half-zymers - where you remember half the sh*t, half the time! (IMG:style_emoticons/default/biggrin.gif) Yes, ground tab added on all 1.8 & 2.0 75-76 MY 914s to ground the relocated to the front trunk fuel pump. So those with older 70-74 914s who do/did the Factory TSB recco to relocate the rear fuel pump up under the steering rack cover, would have to add a drilled/screwed-in ground next to the relocation spot up under there. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
76-914 |
Feb 24 2016, 05:33 PM
Hey Tom, Did ya notice this one's a virgin? As soon as I re-install the OEM alum windshield frame I'm back to 100% stock. And ya'll thought all I did was butcher 'em. (IMG:style_emoticons/default/beerchug.gif)
JFJ914 |
Feb 25 2016, 09:55 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
And by next week I will have probably forgotten again. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/slits.gif) I hear ya on that one Kent! I just write it off as Half-zymers - where you remember half the sh*t, half the time! (IMG:style_emoticons/default/biggrin.gif) Yes, ground tab added on all 1.8 & 2.0 75-76 MY 914s to ground the relocated to the front trunk fuel pump. So those with older 70-74 914s who do/did the Factory TSB recco to relocate the rear fuel pump up under the steering rack cover, would have to add a drilled/screwed-in ground next to the relocation spot up under there. (IMG:style_emoticons/default/beerchug.gif) Tom /////// Or just run the ground to the ground post behind the fuse box. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:35 PM |
