Easy Carb set up, 73-2.0 |
N_Jay |
Mar 2 2016, 01:30 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
I am hoping to get my 914 back on the road after a LONG absence. (20+ years)
I have to drop out my 2.4 engine due to a valve problem and plan on putting back in a stock rebuilt 2.0 engine (originally D-Jetronic). I don't trust the old FI and will only have a couple of weeks from start top finish, so I was thinking of just putting on a set of carbs as an easy fix to get it running. My big engine has a pair of Dellorto cabs that are already a bit too big even for the 2.4, and need to be rebuilt, so again not a good solution. I am looking at either a Dual 40 IDF setup or maybe one of the dual single barrel carb setups. Anyone have any good suggestions. Cost is a concern, so I will probably be looking at the Chinese carbs, EMPI or Webber copies. Thanks in advance. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:20 AM |
