Slightly OT: Bay Area Classic Car Painting Cost, $$$$$ Ouch |
matthepcat |
Mar 2 2016, 05:40 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
So I have been looking to buy a new project fun car, and found a really cool project (280z).
The problem is the car is a color that I dislike. (IMG:style_emoticons/default/sad.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/s30.postimg.org-11125-1456962059.1.jpg) In reaching out to many shops in the bay area for a color change ( windows out, but no engine compartment), the cheapest price I have found is $7,000! I plan to pull everything off the car ( but the glass) before going to the shop. Note: This car is rust free and has no body damage ( original owner since new, and the paint still looks good). Any connections out there for driver quality paint work at 5 grand or below? Once shop quoted me $12k! (IMG:style_emoticons/default/headbang.gif) Thanks for the collective advice, Matt |
EdwardBlume |
Mar 2 2016, 05:50 PM
That's a toughie. Do a wrap?
Tom_T |
Mar 2 2016, 06:03 PM
That $7-112k sounds about the going rate for here in OC/SoCal from a quality shop for a color change - which then adds more spots to repaint (door jambs, trunk or hatch edges in this case, engine bay, etc.) - unless you do a crappy MAACO or 1 Day or Earl Scheib type half-fast paint job.
If you do a color change, I recco you stick with their factory color, but then again, it may also have another more likable color under the yellow, if a PO did a color change. The cheapest route may be to pay for therapy to help you get used to yellow! (IMG:style_emoticons/default/biggrin.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
EdwardBlume |
Mar 2 2016, 06:04 PM
What's wrong with yellow/ (IMG:style_emoticons/default/stirthepot.gif)
matthepcat |
matthepcat |
Mar 2 2016, 06:13 PM
Yellow is for cabs and school bus paint jobs...... (IMG:style_emoticons/default/smile.gif)
I know lots of the people that feel the same about red. |
Series9 |
Mar 2 2016, 06:15 PM
1st, and most important: Remove the glass.
Next: $5k is the going rate in FL for a solid paint job, so $7k in NorCal would probably get you the same. Any color change is very expensive. If you cheap out on a color change, you will very seriously devalue your car. |
EdwardBlume |
Mar 2 2016, 06:31 PM
Yellow is for cabs and school bus paint jobs...... (IMG:style_emoticons/default/smile.gif) I know lots of the people that feel the same about red. Submarines too. (IMG:style_emoticons/default/type.gif) |
ThePaintedMan |
Mar 2 2016, 07:10 PM
(IMG:style_emoticons/default/agree.gif) with Joe. I would imagine cost of materials and the added CA regulations are where the premium comes from in California. No VOC paints anymore, correct? Might *even* be worth trailering the car out of state to get it painted and you'll also be able to go with a non-water-based paint. Last I heard CA had/was moving to all water-based-paints, which despite the good things I've heard, are fairly new.
Mike Bellis |
Mar 2 2016, 07:21 PM
Better call Maaco! Of Earl Shibe
$7k sounds reasonable. You should pull the motor too and interior. Actually Miracle in Pleasanton does lots of muscle cars and quality work. They quoted me $3500 a couple years ago for the 914. I pull all the glass (strip the car) and they would put a less than show quality job on the car. Show quality can run big $$$ depending on your needs. |
JeffBowlsby |
Mar 2 2016, 07:32 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Personally, Luv the yellow...finding another car in a color you like is cheaper.
Go beyond the Bay Area. In Santa Cruz its cheaper, and you can do single stage like the original. |
damesandhotrods |
Mar 2 2016, 07:46 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
steuspeed |
Mar 2 2016, 08:00 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
If you don't like that color, find another car. You better love it b/c you won't see half your money back unless Z cars start getting crazy money.
ConeDodger |
Mar 2 2016, 08:33 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Yellow is for cabs and school bus paint jobs...... (IMG:style_emoticons/default/smile.gif) I know lots of the people that feel the same about red. Not sure how much you know about these cars, but judging by the hood, that's a 77 or 78. In which case it may be a Zap Z. Between the Zap Z and the Black Pearl, they are the only limited edition models Datsun made in the first generation. Very conceivable that the stripes have been taken off in almost 40 years since new. These stripes have been reproduced and are available. Other tell-tale signs of Zap Z or Black Pearl models are a matching passenger side mirror and rear louvre red sun shade. If there's a chance this is a Zap Z, don't change the color! Attached image(s) |
Puebloswatcop |
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Sounds like it is time for a road trip....that is outrageous for any paint job.
bigkensteele |
Mar 2 2016, 08:50 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Personally, I would bring the paint back to its best possible condition and drive it for awhile. You may learn to like it. I hated the color of my current 914 until my cousin and I spent an afternoon polishing and waxing it. After we were done, I loved it. It still needs a paint job, but I am staying with Laguna Blau.
Andyrew |
Mar 2 2016, 09:23 PM
It takes at least 100 hours start to finish for a single man assuming little bodywork for a shop quality job. Then you have about 1500 in materials/consumables for decent stuff and 600-1k for cheap stuff. So ya.
Mayco will do a decent job for around 3k, but you have to talk to them in detail about it an agree to extra layers of base and clear, having their expert painter spray it, and for them to do a coat of primer before hand and finish it with a good cut and buff. Ive had requests to paint cars but being to busy to take on any job like that I always just reccomend going to Mayco. |
altitude411 |
Mar 2 2016, 09:33 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
7K? Pffft I paid that for non-color change in the bay area 20 years ago... (IMG:style_emoticons/default/headbang.gif) I just got a quote from a shop for body work on a reasonable clean six (already completly stripped and no re-assembly) He wanted 25K before paint. (IMG:style_emoticons/default/av-943.gif)
Coondog |
Mar 2 2016, 10:27 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Did that price include pulling off the ugly 70s side molding and filing in the holes that are no doubt running down each side.
I have passed on many a car because of aftermarket 70s side molding. |
matthepcat |
Mar 3 2016, 12:51 AM
Thanks for the replies all! Details on the car:
1975 and the original color was a gold color. (So a color change is no big deal) What's cool about the car is a JDM RB25DET fresh rebuild with forged internals. (445hp on low boost 91 pump gas tune) Interior is pristine and body in excellent shape. Obviously im not concerned about originality. The vents in the hood are aftermarket for heat control and a vent for the wastegate. Prices quote did not include any hole filling for side molding removal. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:29 AM |
