big progress recently,, filled the hole in the engine space with the right motor? |
porschetub |
Mar 8 2016, 01:50 AM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Perry Kiehl Clone |
Aug 26 2016, 09:15 AM
Unregistered |
Very nice!
I'd opine that your throttle action will be a little wonky, as the geometry of your bellcrank at the transmission is different from a 914-6. It will probably work like you have it, but it won't be smooth as you are giving up some mechanical advantage off idle. I've been around the block on this and found there's a reason the 6 bellcranks are different (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 07:55 AM |
