big progress recently,, filled the hole in the engine space with the right motor? |
porschetub |
Mar 8 2016, 01:50 AM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
porschetub |
Oct 2 2016, 02:30 PM
Now that I have my oil pressure sorted I started getting the driveshafts in so it can be driven on to my loaner trailer and around to my mates shop to remove the engine/gearbox on his hoist.
Worked on carbs yesterday and found 2 small leaks on the RH side one,turned out I hadn't tightened the the 2 brass caps in the top enough. Valve cover leaks are pretty much sorted,only found one of the 3 that weren't twisted,glued course sandpaper to a sheet of glass and worked them flat again. Today I hope to get the fuel pump running of the ignition but early indication is that the black/red wire in the loom has a break in it somewhere as I can't find power there but I have it in the 14 pin plug,old cars aren't they fun???? |
Lo-Fi Version | Time is now: 24th May 2024 - 06:19 PM |
