Muffler conversion for a six, 2 in,2 out... |
DougC |
Mar 24 2005, 10:19 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
OK so I have a used stainless Dansk muffler that I will be using on my six and I have to do something about the single "out" pipe because it is really twisted and bent up pretty bad, but the rest of the muffler is really nice. I'd like to do the conversion to "2 out" pipes and have a question or two. First, what size pipes should I be using for a stock 2.7L engine with CIS? Smaller pipe is more restrictive, will the 2.7 benifit from that or should I go for less restrictive. There may not even be enough of a difference to notice, I don't know. Also, will I be able to find this pipe in stainless? I guess the best place to get it is at a muffler shop? Any other suggestions? Thanks!
Doug C |
Joe Bob |
Mar 24 2005, 10:28 AM
Depends....are you gonna do a two out pipe at each end of the banana? Or are ya gonna do the two center exit sport muff version?
The center exit sport muff version also has been done with the stock end STILL used. What this allows....along with the internal mods ....is the capping of one or two of the exits to modulate noise.... Someplace there is a schematic on how to do a Sport Muff mod....unless someone else has it handy. You might wanna try and post on the PParts 911 board for the text....or do a search of the help articles over there. |
DougC |
Mar 24 2005, 10:57 AM
(LOL) thanks Mike, and I was considering buying Manfred from you.. No, I already have the sceamatic and diagram that you're referring to but they don't address my questions. BTW, I should have said I wanted the center pipes configuration for the Sport Muffler look. Basically, I was looking for any opinions on the effects of pipe diameter in regards to a stock 2.7 w/CIS. Now that you mention it, I do remember seeing a sport muffler in a recent Excellence with a capped off stock pipe, just not sure I liked the look though. I hope the sport muffler doesn't end up being too,too loud. Thanks for the suggestions!
Doug C |
Joe Bob |
Mar 24 2005, 11:13 AM
Go two inch....you can always use supertrapp diffusers on the ends if too loud or cap one.
(IMG:http://members.rennlist.com/tweedt/sptmuff.jpg) |
dinomium |
Mar 24 2005, 11:19 AM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
I wonder if the /4 banana is the same inside? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
I have welder and a banana just sitting there in the shop... |
Joe Bob |
Mar 24 2005, 11:21 AM
Open it up and find out.....take pics and post the results.
Aaron Cox |
Mar 24 2005, 11:22 AM
i just thought the same thing! |
dinomium |
Mar 24 2005, 11:24 AM
sounds like I need my own Plasma torch...
Joe Bob |
Mar 24 2005, 11:30 AM
What do ya think about a SINGLE oval type exit in the middle ala Boxster?
Aaron Cox |
Mar 24 2005, 11:47 AM
do it! we can critcize you later (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Joe Bob |
Mar 24 2005, 12:40 PM
Oh thanks....a heap. Was thinking of a different look on Frank for the rear.....the engine likes back pressure but it needs a center outlet just to be different....duals would be too....50s....
JmuRiz |
Mar 24 2005, 01:15 PM
914 Guru Group: Members Posts: 5,431 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Could do duals in the middle, like a boxster S (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
maf914 |
Mar 24 2005, 01:33 PM
When you look at the stock muffler, you can trace the exhaust flow into the main chamber, through the short pipe, through the long pipe and through the various chambers. You can sort of see how this single muffler is really a series of pipe and mufflers. Someone probably spent a lot of time testing and experimenting to come up with this.
When you look at the modified sport muffler, you can see the exhaust flow enter the main chamber and then exit the main chamber. All of the internal pipe, chambers, baffles, etc. are now just along for the ride. Makes me wonder why you even start with a muffler and not just a blank steel tube? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
dinomium |
Mar 24 2005, 01:56 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) look at that! I am thinking that if you do this the way it is shown, you will have some really heavy straight pipes. |
Lo-Fi Version | Time is now: 24th May 2024 - 06:18 PM |
