Proper part #'s for -6 oil line with Carrera tensioner update?, confusing |
mskala |
Mar 11 2016, 01:01 PM
I'm trying to understand the correct oil line to buy for a -6 when you are using
Carrera tensioners. For the (4-5-6) bank, I got one that is too short. If I remember correctly, later engine cases had another big sender/adapter sticking out in that location. I also found this line on Paragon-products "1967-73 engines will require an adapter to properly space the right side cam tower oil line." So, anybody know where to get a proper adapter, or if there's a real oil line still made that will be long enough? (I know I had one 15 years ago) Thanks |
Lo-Fi Version | Time is now: 28th May 2024 - 07:00 AM |
