I'm trying to understand the correct oil line to buy for a -6 when you are using
Carrera tensioners. For the (4-5-6) bank, I got one that is too short.
If I remember correctly, later engine cases had another big sender/adapter sticking
out in that location. I also found this line on Paragon-products "1967-73 engines will require an adapter to properly space the right side cam tower oil line."
So, anybody know where to get a proper adapter, or if there's a real oil line still made that will be long enough? (I know I had one 15 years ago)
Thanks
