Tail to Side Shift Conversion Rookie |
Jameel |
Mar 12 2016, 08:25 AM
Member Group: Members Posts: 98 Joined: 6-October 15 From: Iowa Member No.: 19,239 Region Association: None |
A few days ago I decided to take a closer look at my shift linkage, since my car has some serious issues. Took that rear cover off and found this: https://youtu.be/gtFysPUBIO0
I'm no engineer, but that looks nasty to me. I decided to fix it right. So yesterday I made a trip to 914 Limited and was treated quite well by Brad and Mike. Brad and I had exchanged a couple emails and calls and since I'm less than 3 hours from Peoria, I decided to kill two birds and simply drive in. Brad was kind enough to let me drive his daily 914 to see what a side shifter felt like. Took me about 1/3 mile to decide I would do the conversion. Brad and Mike walked me through a few of the finer points of the process, but this being my first time opening up a transaxle, I figured I'd try and document as much as possible. I've done a bunch of searches here (and at Pelican) but have not found much in terms of step-by-step. Brad's instructions were provided, and he invited me to call anytime for support, but I'll be taking pics anyway, so figured I'd start a thread. Can anyone point me to a thread where someone has documented the process? The best I've found so far is mikedsilva's, here. I could not find others. Sort of off topic too, but is there any way to get rid of the huge smileys window when composing a post? My composition pane is just tiny, like 1/4 the size of the smileys pane. |
zambezi |
Mar 19 2016, 10:18 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
watch out on the reverse light switch. There should be a small rod in the hole that pushes into the switch to activate the switch. Look in the hole in the trans to see if it is still there. If it is it may fall out and you won't notice it.
Jameel |
Mar 20 2016, 11:38 AM
watch out on the reverse light switch. There should be a small rod in the hole that pushes into the switch to activate the switch. Look in the hole in the trans to see if it is still there. If it is it may fall out and you won't notice it. Great info! I read about that in the Haynes manual, but sort of spaced it out. Going to fetch it now. Thanks Dr. Evil. DVD ordered, $ sent. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:17 PM |
