Tail to Side Shift Conversion Rookie |
Jameel |
Mar 12 2016, 08:25 AM
Member Group: Members Posts: 98 Joined: 6-October 15 From: Iowa Member No.: 19,239 Region Association: None |
A few days ago I decided to take a closer look at my shift linkage, since my car has some serious issues. Took that rear cover off and found this: https://youtu.be/gtFysPUBIO0
I'm no engineer, but that looks nasty to me. I decided to fix it right. So yesterday I made a trip to 914 Limited and was treated quite well by Brad and Mike. Brad and I had exchanged a couple emails and calls and since I'm less than 3 hours from Peoria, I decided to kill two birds and simply drive in. Brad was kind enough to let me drive his daily 914 to see what a side shifter felt like. Took me about 1/3 mile to decide I would do the conversion. Brad and Mike walked me through a few of the finer points of the process, but this being my first time opening up a transaxle, I figured I'd try and document as much as possible. I've done a bunch of searches here (and at Pelican) but have not found much in terms of step-by-step. Brad's instructions were provided, and he invited me to call anytime for support, but I'll be taking pics anyway, so figured I'd start a thread. Can anyone point me to a thread where someone has documented the process? The best I've found so far is mikedsilva's, here. I could not find others. Sort of off topic too, but is there any way to get rid of the huge smileys window when composing a post? My composition pane is just tiny, like 1/4 the size of the smileys pane. |
Jameel |
Mar 30 2016, 07:24 PM
I just resurfaced mine for my six conversion. For $40 bucks there's no reason not to. Also replaced the bearing. It's just a couple dollars. I didn't get off quite so cheap. Mine was $73. But I ain't complaining! Things to consider: 1) Was the flywheel finished to within spec? ***Yes. I got the print from one of your old threads. And confirmed with Brad M. before heading to the shop. 2) You may need to grind down, ever so specifically, the tops of the new flywheel bolts as the clutch disk will sit closer to the crank and will often hit the bolt heads after an aggressive resurface such as what looks like you needed. ***They took off 0.023". And I still got groove. I was planning on grinding off .023" 3) You will need to put another washer under the pivot ball. Use teflon tape as the threads with two washers will seep oil pretty easily. ***Ok, will do. One thing I spotted early on--one of the wires going to the interior light is always "hot". So either disconnect the battery or tape up the black wire so it doesn't short to ground. --DD I disconnected the batt. But I'll remember that! |
Lo-Fi Version | Time is now: 17th May 2024 - 06:30 PM |
