Tail to Side Shift Conversion Rookie |
Jameel |
Mar 12 2016, 08:25 AM
Member Group: Members Posts: 98 Joined: 6-October 15 From: Iowa Member No.: 19,239 Region Association: None |
A few days ago I decided to take a closer look at my shift linkage, since my car has some serious issues. Took that rear cover off and found this: https://youtu.be/gtFysPUBIO0
I'm no engineer, but that looks nasty to me. I decided to fix it right. So yesterday I made a trip to 914 Limited and was treated quite well by Brad and Mike. Brad and I had exchanged a couple emails and calls and since I'm less than 3 hours from Peoria, I decided to kill two birds and simply drive in. Brad was kind enough to let me drive his daily 914 to see what a side shifter felt like. Took me about 1/3 mile to decide I would do the conversion. Brad and Mike walked me through a few of the finer points of the process, but this being my first time opening up a transaxle, I figured I'd try and document as much as possible. I've done a bunch of searches here (and at Pelican) but have not found much in terms of step-by-step. Brad's instructions were provided, and he invited me to call anytime for support, but I'll be taking pics anyway, so figured I'd start a thread. Can anyone point me to a thread where someone has documented the process? The best I've found so far is mikedsilva's, here. I could not find others. Sort of off topic too, but is there any way to get rid of the huge smileys window when composing a post? My composition pane is just tiny, like 1/4 the size of the smileys pane. |
SKL1 |
Mar 19 2016, 10:16 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Wonder why you had to cut out that access hole in the tunnel? When I converted my '71 to a side shifter MANY years ago I didn't have to do that.
When adjusting the shift rod, if you experience difficulties, Tangerine makes a slick part that allows easier adjustment- check Tangerine Racing website... |
brant |
May 21 2016, 12:11 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Wonder why you had to cut out that access hole in the tunnel? When I converted my '71 to a side shifter MANY years ago I didn't have to do that. When adjusting the shift rod, if you experience difficulties, Tangerine makes a slick part that allows easier adjustment- check Tangerine Racing website... Agreed. No cutting necessary |
Lo-Fi Version | Time is now: 17th May 2024 - 08:27 PM |
