Any six cylinder guys have an answer to this?, Need to remove the blob from this shaft |
Thorshammer |
Mar 24 2005, 11:16 PM
Senior Member Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 |
So heres the deal.
This alternator shaft weighs a ton and I don't need no stinking amps, so I gutted the housing, now I want to gut this thing. I have tried turning on my lathe, but the casing seems really hard. maybe heat treated over the years??? Any suggestions, someone make a shaft to eliminate this piece, probably do I'm just too stupid to know, it's killing me, HELP!!!!! Motor must go in on saturday. Erik Attached image(s) |
J P Stein |
Mar 25 2005, 02:50 AM
Humm....you have a lathe?......Make a new shaft. The only problem I see is a new key way. Woodruf keys are a PITA.
Take a Rockwell reading, take the reading to a machine supply house and tell them you want a cutter for your lathe that can deal with it. If it's below 45C, it shouldn't be a problem. |
gaz914 |
Mar 25 2005, 03:34 AM
Member Group: Members Posts: 67 Joined: 6-March 04 From: Sydney, Australia Member No.: 1,758 Region Association: None |
The "thing" is called a rotor.
Apart from the electrical properties (which it sounds like you don't want), the rotor dimensions keep the bearings in the right place. The "claws" (rusty looking bits) can be pressed off toward the threaded end, although you really need a suitable plate that supports the ends of the "claw" as you press it out. Probably more trouble then its worth for a "one off". I would think the easiest way would be to turn up a "dummy" shaft, making sure there was a shoulder for the front bearing retainer. This is what the nut tightens up on when you put the fan belt on so there is a fair bit of force on it. Then it is a simple matter turn the shaft down to suit the back bearing and your done. |
Thorshammer |
Mar 26 2005, 09:31 PM
I tried to press the shaft off of the rotor, made tool and everything. I had 35 ton on it and it went no where. So I cut the fingers off and turned the exterior down on the lathe. Just needed some carbide cutters. Did'nt have any. This would be something nice to make. I may spin up a couple of these. May not need a key way since the load is limited.
Erik |
Lo-Fi Version | Time is now: 10th May 2024 - 02:50 AM |
