Suspension Question, What is normal...? |
Ansbacher |
Mar 18 2016, 08:20 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
When I sit in the driver's seat of my '74 2.0 the car dips on that that side by 1 centimeter or so when measuring from the ground up to the fender wheel arch, passing through the center of the wheel. I get the same measurement at front and rear wheels. I weigh 190 lbs. Is that excessive sag? My shocks (Boges) are less than 2 years old. Opinions?
Ansbacher |
Mar 18 2016, 09:19 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Sounds about right.
That is also why you need to add your wieght to the drivers seat when corner balancing a car ... (IMG:style_emoticons/default/shades.gif) |
Mar 18 2016, 09:32 PM
Yup, or crank up the drivers side front torsion bar 1/4 of an inch higher so the car sits level with you in there.
Ansbacher |
Mar 19 2016, 08:18 AM
Thanks all. I will study up on the torsion bar adjustment. I've never messed with them before.
Ansbacher |
rgalla9146 |
Mar 19 2016, 08:54 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Shocks don't support weight.
Lo-Fi Version | Time is now: 18th May 2024 - 02:32 AM |
