Ansbacher
Mar 18 2016, 08:20 PM
When I sit in the driver's seat of my '74 2.0 the car dips on that that side by 1 centimeter or so when measuring from the ground up to the fender wheel arch, passing through the center of the wheel. I get the same measurement at front and rear wheels. I weigh 190 lbs. Is that excessive sag? My shocks (Boges) are less than 2 years old. Opinions?
Ansbacher
Mar 18 2016, 09:19 PM
Sounds about right.
That is also why you need to add your wieght to the drivers seat when corner balancing a car ...
r_towle
Mar 18 2016, 09:32 PM
Yup, or crank up the drivers side front torsion bar 1/4 of an inch higher so the car sits level with you in there.
Ansbacher
Mar 19 2016, 08:18 AM
Thanks all. I will study up on the torsion bar adjustment. I've never messed with them before.
Ansbacher
rgalla9146
Mar 19 2016, 08:54 AM
Shocks don't support weight.
