Bleeding Brakes, Bleeding Brakes |
Gromicko |
Mar 19 2016, 07:23 AM
Gromicko Group: Members Posts: 7 Joined: 19-August 15 From: Pennsylvania Member No.: 19,081 Region Association: MidAtlantic Region |
I recently had all 4 calipers on my 1971 914 rebuilt because it had been sitting for decades. The brakes worked, but stuck, and a had a small leak. I put the calipers back on, but now can't get brake fluid to flow through the lines in order to bleed the brakes. I've tried a hand vacuum pump on the bleeder screws, even disconnected the lines at the calipers. The reservoir is full, but I can get the fluid to flow. Can I hook up an electric high vacuum pump to the lines? I'm afraid I'll damage the rebuilt calipers. Any suggestions? Can you send instructions?
Thank you, Greg |
stugray |
Mar 19 2016, 08:02 AM
Replace the flex lines.
They swell internally and block the flow. |
dangrouche |
Mar 19 2016, 08:46 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
tomrev |
Mar 19 2016, 08:58 AM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
New MC's frequently want to be bench bled, to get fluid flowing, before even installing in the car. I do it over my parts cleaner, with plastic lines going right back into the res.,cycle it till it flows, then clean up, and installing the car. It can be frustrating! |
Bulldog9 |
Mar 19 2016, 09:54 AM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
As Stu said, if you havent yet, replace the flex lines. Also I've found the vacuum or pull method less effective than the push. I bought one of those 'push' bleeders and it works outstanding. Comes with adapters for other vehicle MC as well. Just make sure you clamp the MC overflow line.
Gromicko |
Mar 19 2016, 05:03 PM
Thank you all. I will replace the flex lines and try the pressure bleeding.
Greg |
BeatNavy |
Mar 19 2016, 05:17 PM
I bought one of those 'push' bleeders and it works outstanding. (IMG:style_emoticons/default/agree.gif) I bought one of these: http://www.pelicanparts.com/More_Info/PEL0...amp;SVSVSI=9144 It works like a champ and ends up being a one man operation. The family is glad that I don't have to draft them into helping with the bleeding operation. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:39 PM |
