Hell Hole Water Exhaust Nozzle, What is the water nozzle all about in the hell hole? 76-914 |
matchpoint |
Mar 19 2016, 12:10 PM
Newbie Group: Members Posts: 16 Joined: 19-March 16 From: Oregon Member No.: 19,783 Region Association: Pacific Northwest |
Does anyone have any idea about a small nozzle located in the hell hole on the drivers side. My car is a 1976 - 914 and the hell hole is dry and in rust free condition. In checking he condition of the hell hole I noticed a small what looked to be water nozzle that is pressed in at the lower engine side edge of the hell hole. What is the purpose of the nozzle? Must be some kind of factory installed one way water nozzle/valve to make sure water goes out but not into the hell hole. I noticed the nozzle was missing from the passenger side hell hole as it must have fallen out over time as the hole diameter is enlarged due to rusting. Any idea the purpose of the nozzles? I have searched the PET's and can not find a Part Number or description of these nozzles.
colingreene |
Mar 19 2016, 12:11 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Sounds like the Previous owner pushed something into the hole.
dlee6204 |
Mar 19 2016, 12:16 PM
It's a drain. The hell hole has to drain somehow.... Most of them got clogged up with debris early on causing water to sit thus rusting.
Chris914n6 |
Mar 19 2016, 12:17 PM
Jackstands are my life. Group: Members Posts: 3,321 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
There is/was a rubber drain valve like piece there. It often clogged causing water to puddle. The designers put a lot of effort into keeping the airflow top to bottom, thus a drain valve instead of just a hole.
Lo-Fi Version | Time is now: 22nd May 2024 - 04:50 AM |
