flywheel bolts, how to un-do |
Randal |
Mar 25 2005, 03:05 PM
Do they come off counter clockwise?
Also how much are they torqued? |
Allan |
Mar 25 2005, 03:08 PM
Counter clockwise and 80 ft. lbs. is spec. If they have been ground down it can be a bitch. Mine were and I ended up using and impact gun.
Joe Bob |
You either need to brace the flywheel or use an air tool....
Mueller |
Mar 25 2005, 03:43 PM
they could have Loc-tite on them......if so, bring out the heat (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Randal |
Mar 25 2005, 03:46 PM
Thank you, thank you.
It's off. No lock-tite, but it must have been torqued much higher than 80lbs as I broke a socket. As far as holding the flywheel, I used lock pliers against one of the bigger bolts out of the case as a stop, with a rag in between. |
Lo-Fi Version | Time is now: 13th May 2024 - 09:22 PM |
