Randal
Mar 25 2005, 03:05 PM
Do they come off counter clockwise?
Also how much are they torqued?
Allan
Mar 25 2005, 03:08 PM
Counter clockwise and 80 ft. lbs. is spec. If they have been ground down it can be a bitch. Mine were and I ended up using and impact gun.
Joe Bob
You either need to brace the flywheel or use an air tool....
Mueller
Mar 25 2005, 03:43 PM
they could have Loc-tite on them......if so, bring out the heat
Randal
Mar 25 2005, 03:46 PM
Thank you, thank you.
It's off. No lock-tite, but it must have been torqued much higher than 80lbs as I broke a socket.
As far as holding the flywheel, I used lock pliers against one of the bigger bolts out of the case as a stop, with a rag in between.
