992 pounds, German, midengine |
seanery |
Mar 25 2005, 04:30 PM
I knew 550s were light, but man, that is crazy light!
There is a nice little article in the current Panorama 550 vs 2005 Box S. They list the dry weight of a 550 at 992 lbs! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I want one sooooo bad! |
ChrisReale |
Mar 25 2005, 04:32 PM
Damn, there are people that weigh that much (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif)
fiid |
Mar 25 2005, 04:43 PM
TheCabinetmaker |
Mar 25 2005, 04:49 PM
Nooooo!!!! No pics of 900 pound people!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif)
ChrisReale |
Mar 25 2005, 04:58 PM
sorry....(IMG:http://www.fatchicksinpartyhats.com/images/fathat180.jpg)
Mar 25 2005, 05:00 PM
Had to
tommy914 |
Mar 25 2005, 05:02 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
Since I'll never be able to drive a real one, I have to say, on Need for Speed Porsche Unleashed, the 550 was a real handful. Must have been the skinny tires. Or maybe the data model was wrong. |
ken914 |
Mar 25 2005, 05:07 PM
Whole lot 'O 914/6 Group: Members Posts: 157 Joined: 15-November 04 From: Mount Pleasant, SC Member No.: 3,122 |
Something was screwy about that number. They said 992 lbs dry and over 1200 with 24 gallons of gas in it. Gas only weights 6 lbs per gallon! Must be some of that German math, where less is more...
fiid |
Mar 25 2005, 05:08 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) lmao. Guess I asked for that.
lapuwali |
Dunno why anyone should be so surprised at this. A 550 tube frame is pretty insubstantial, and the engine and gearbox are both very light units. Consider a Formula Ford is about 1000lbs, and it has an iron-block engine in it that's much heavier than a Type I or a four-cam. A modern F-Ford probably has a heavier frame, in fact, just because of crash protection concerns that didn't exist in the 50s. A winning Formula SAE car is now under 500lbs. Some are under 450lbs, and that's with four-wheel brakes, full suspension, and full rollover protection. They get to be lighter even than the 550 mostly because they're single-seaters, and the engine/gearbox package is usually under 150lbs. SCCA A-Mod AX class rules specify a 750lb minimum weight, and there are several cars built right to that limit. Bowland, Whittle, and others are using two-stroke watercraft engines now to remove weight. |
Demick |
Mar 25 2005, 05:10 PM
Bonehead who calculated that assumed that gasoline weighs the same as water. Water: 8.33 lbs/gal Gasoline: 5.8-6.5 lbs/gal Makes a big difference Demick |
Jeroen |
Mar 25 2005, 07:25 PM
did you ever stand up close and personal with a 550?
they're scarry small, so small in fact that the driver more sits ON it than in it |
URY914 |
Mar 25 2005, 07:46 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,530 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I got my work cut out for me.
OK, 991 lbs is my new goal. (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) Paul (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
redshift |
Mar 25 2005, 08:10 PM
lol
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Go Paul! I like the 962 streeter better. M |
jd74914 |
Mar 25 2005, 08:45 PM
I've sat in some replicas. I agree, they are really, really, really small. I still really want to build one. The only problem is that I'm 6'2" and still growing. I guess I'll just have to sacrifice and do a 356 (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
grantsfo |
Mar 25 2005, 09:56 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
There isnt much to them. There were a few that use to show up to AX's back in the 1970's and they flew. Made 914's look big.
Trekkor |
Mar 25 2005, 10:09 PM
This guy is very fast up in Sonoma.
KT Attached image(s) |
Trekkor |
Mar 25 2005, 10:12 PM
Demick |
Mar 25 2005, 10:17 PM
Yep - one of these days when I have enough shop/garage space I'm going to build myself one of those.
Demick |
ChrisReale |
Mar 25 2005, 10:18 PM
I like. Who makes the replica's? Beck's? One of those with a wild RAT 4 banger would be fun
Lo-Fi Version | Time is now: 11th May 2024 - 10:55 PM |
