seanery
Mar 25 2005, 04:30 PM
I knew 550s were light, but man, that is crazy light!
There is a nice little article in the current Panorama 550 vs 2005 Box S.
They list the dry weight of a 550 at 992 lbs!
I want one sooooo bad!
ChrisReale
Mar 25 2005, 04:32 PM
Damn, there are people that weigh that much
fiid
Mar 25 2005, 04:43 PM
TheCabinetmaker
Mar 25 2005, 04:49 PM
Nooooo!!!! No pics of 900 pound people!!!!
ChrisReale
Mar 25 2005, 04:58 PM
sorry....
r_towle
Mar 25 2005, 05:00 PM
Had to
tommy914
Mar 25 2005, 05:02 PM
QUOTE (seanery @ Mar 25 2005, 05:30 PM) |
Since I'll never be able to drive a real one, I have to say, on Need for Speed Porsche Unleashed, the 550 was a real handful. Must have been the skinny tires. Or maybe the data model was wrong.
ken914
Mar 25 2005, 05:07 PM
Something was screwy about that number. They said 992 lbs dry and over 1200 with 24 gallons of gas in it. Gas only weights 6 lbs per gallon! Must be some of that German math, where less is more...
fiid
Mar 25 2005, 05:08 PM
lmao. Guess I asked for that.
lapuwali
QUOTE (seanery @ Mar 25 2005, 02:30 PM) |
There is a nice little article in the current Panorama 550 vs 2005 Box S. They list the dry weight of a 550 at 992 lbs!
I want one sooooo bad! |
Dunno why anyone should be so surprised at this. A 550 tube frame is pretty insubstantial, and the engine and gearbox are both very light units. Consider a Formula Ford is about 1000lbs, and it has an iron-block engine in it that's much heavier than a Type I or a four-cam. A modern F-Ford probably has a heavier frame, in fact, just because of crash protection concerns that didn't exist in the 50s.
A winning Formula SAE car is now under 500lbs. Some are under 450lbs, and that's with four-wheel brakes, full suspension, and full rollover protection. They get to be lighter even than the 550 mostly because they're single-seaters, and the engine/gearbox package is usually under 150lbs. SCCA A-Mod AX class rules specify a 750lb minimum weight, and there are several cars built right to that limit. Bowland, Whittle, and others are using two-stroke watercraft engines now to remove weight.
Demick
Mar 25 2005, 05:10 PM
QUOTE (ken914 @ Mar 25 2005, 03:07 PM) |
Something was screwy about that number. They said 992 lbs dry and over 1200 with 24 gallons of gas in it. Gas only weights 6 lbs per gallon! Must be some of that German math, where less is more... |
Bonehead who calculated that assumed that gasoline weighs the same as water.
Water: 8.33 lbs/gal
Gasoline: 5.8-6.5 lbs/gal
Makes a big difference
Demick
Jeroen
Mar 25 2005, 07:25 PM
did you ever stand up close and personal with a 550?
they're scarry small, so small in fact that the driver more sits ON it than in it
URY914
Mar 25 2005, 07:46 PM
I got my work cut out for me.
OK, 991 lbs is my new goal.
Paul
redshift
Mar 25 2005, 08:10 PM
lol
Go Paul!
I like the 962 streeter better.
M
jd74914
Mar 25 2005, 08:45 PM
QUOTE (Jeroen @ Mar 25 2005, 05:25 PM) |
did you ever stand up close and personal with a 550? they're scarry small, so small in fact that the driver more sits ON it than in it |
I've sat in some replicas. I agree, they are really, really, really small. I still really want to build one. The only problem is that I'm 6'2" and still growing. I guess I'll just have to sacrifice and do a 356
grantsfo
Mar 25 2005, 09:56 PM
There isnt much to them. There were a few that use to show up to AX's back in the 1970's and they flew. Made 914's look big.
Trekkor
Mar 25 2005, 10:09 PM
This guy is very fast up in Sonoma.
KT
Trekkor
Mar 25 2005, 10:12 PM
Demick
Mar 25 2005, 10:17 PM
Yep - one of these days when I have enough shop/garage space I'm going to build myself one of those.
Demick
ChrisReale
Mar 25 2005, 10:18 PM
I like. Who makes the replica's? Beck's? One of those with a wild RAT 4 banger would be fun
Trekkor
Mar 25 2005, 10:32 PM
If I ever built one, I'd do a SIX.
KT
URY914
Mar 25 2005, 10:37 PM
Gunnar built a batch of them and put Type-1's in them.
sixnotfour
Mar 25 2005, 10:39 PM
Trekkor's a SIX addict, may need to plan an intervention before he goes to 3.6
KaptKaos
Mar 25 2005, 10:43 PM
You sure it wasn't 992 Kilos?
I had read that they were about 1500 pounds with a full tank, so that 998 kilos would be with driver (and passenger?).
grantsfo
Mar 26 2005, 01:00 AM
QUOTE (trekkor @ Mar 25 2005, 08:32 PM) |
KT |
Like this one?
Trekkor
Mar 26 2005, 01:42 AM
550Club.com here I come...
KT
