What material is the brake and clutch pedal made of?, Cast or cut steel? |
Andyrew |
Mar 23 2016, 10:07 AM
Mocking up how to install all the sensors for my clutch and brake pedals I was thinking the best solutions will be to weld on tabs for the trigger sensors on my wiring harness. However If the pedals are made from cast I know I will probably just drill through and bolt a tab on.
Anyonr know? Thanks! |
Mueller |
Mar 23 2016, 10:49 AM
From memory I'd say stamped/cut steel plate or sheet.
McMark |
Mar 23 2016, 10:53 AM
Well.... clutch is a threaded rod and a cast arm, brake is all welded/stamped.
So a little of both. (IMG:style_emoticons/default/sad.gif) |
ChrisFoley |
Mar 23 2016, 11:14 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The castings are steel, not iron.
NO problem welding and grinding on them. |
Andyrew |
Mar 23 2016, 11:35 AM
Thanks guys!
914-d |
Mar 26 2016, 08:46 PM
Newbie Group: Members Posts: 37 Joined: 6-June 13 From: nor cal Member No.: 15,974 Region Association: Northern California |
I am going through the same situation. DBW pot is mounted, hydraulic clutch is setup.
I have just about decided to make saddle brackets to go around the peddle. Cut a piece out of a Jetta yesterday with the correct holes for the brake and clutch switches. Will make a bracket welded lto the peddle base |
Lo-Fi Version | Time is now: 28th May 2024 - 10:48 AM |
