Andyrew
Mar 23 2016, 10:07 AM
Mocking up how to install all the sensors for my clutch and brake pedals I was thinking the best solutions will be to weld on tabs for the trigger sensors on my wiring harness. However If the pedals are made from cast I know I will probably just drill through and bolt a tab on.
Anyonr know?
Thanks!
Mueller
Mar 23 2016, 10:49 AM
From memory I'd say stamped/cut steel plate or sheet.
McMark
Mar 23 2016, 10:53 AM
Well.... clutch is a threaded rod and a cast arm, brake is all welded/stamped.
So a little of both.
ChrisFoley
Mar 23 2016, 11:14 AM
The castings are steel, not iron.
NO problem welding and grinding on them.
Andyrew
Mar 23 2016, 11:35 AM
Thanks guys!
914-d
Mar 26 2016, 08:46 PM
I am going through the same situation. DBW pot is mounted, hydraulic clutch is setup.
I have just about decided to make saddle brackets to go around the peddle. Cut a piece out of a Jetta yesterday with the correct holes for the brake and clutch switches. Will make a bracket welded lto the peddle base
