Trans mount mock up |
spare time toys |
Mar 25 2005, 05:48 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Rick sent me a diagram for his trans mount. I did not have all the items listed for his style but I did have 1.5 inch bar stock I could use. I need to relocate the mount bolt 1.5 inches aft and when I do this it puts the trans bolt overlapping the rear hanger bolt. What my thought is I can weld a plate betweew the two hangers and open up the aft mount hole to fit the rear trans bolt..
Attached image(s) |
spare time toys |
Mar 25 2005, 05:50 PM
then when it is up and in place it would look something like this
Attached image(s) |
spare time toys |
Mar 25 2005, 10:12 PM
put the plate in here and redrill the aft hole
Attached image(s) |
i love porsche |
Mar 26 2005, 01:37 AM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
are you going to fix some of that rust?? (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
spare time toys |
Mar 26 2005, 05:05 AM
Im doing thie mock up on the Banana not the German 8 Tor. When it is its turn to be worked on I plan to replace the trunk floor.
davep |
Mar 26 2005, 06:15 AM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
It would appear that this will increase (almost double) the stress on the rear bracket. I would reinforce the rear brackets to compensate. Perhaps even make a spacer block to bolt on top of the one you have there to fit snugly between the two brackets, and a through bolt to tie them together. I assume that this is to fit a non-stock engine with increased power and perhaps more weight. Even more reason to ensure the bracket won't fail.
spare time toys |
Mar 26 2005, 03:22 PM
I plan to brace them up some. As for going big on the engine its for the 928 powered car. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 12:56 PM |
