Tired of Carbs want injection, Have 74 1.8L dual webber going to injection |
ausDan |
Mar 23 2016, 10:26 PM
Newbie Group: Members Posts: 6 Joined: 23-March 16 From: Austin,TX Member No.: 19,802 Region Association: Southwest Region |
I bought a 74 1.8L that has dual Webbers, and it is really a pain starting it in cool weather, and it backfires after releasing the accelerator. I recently bought a "complete fuel injection taken from a running 1975 1.8", and I am interested in knowing if I will have compatibility issues. My desire is to return this car to its stock configuration as a casual driver.
saigon71 |
Mar 24 2016, 06:08 AM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I bought a 74 1.8L that has dual Webbers, and it is really a pain starting it in cool weather, and it backfires after releasing the accelerator. I recently bought a "complete fuel injection taken from a running 1975 1.8", and I am interested in knowing if I will have compatibility issues. My desire is to return this car to its stock configuration as a casual driver. The only compatibility issues would be if a non FI camshaft was installed for those carbs. Any idea what camshaft is in your engine? Stock FI is an excellent system for a stockish car. It may take some time to sort it out, but it's worth the effort in my opinion. |
ClayPerrine |
Mar 24 2016, 11:04 AM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I bought a 74 1.8L that has dual Webbers, and it is really a pain starting it in cool weather, and it backfires after releasing the accelerator. I recently bought a "complete fuel injection taken from a running 1975 1.8", and I am interested in knowing if I will have compatibility issues. My desire is to return this car to its stock configuration as a casual driver. I can help and I am in the DFW area. We are doing one for Rob-o in the near future, and you are welcome to join us. |
Mar 24 2016, 11:35 AM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Stock FI is an excellent system for a stockish car. It may take some time to sort it out, but it's worth the effort in my opinion. (IMG:style_emoticons/default/agree.gif) |
tomrev |
Mar 24 2016, 11:43 AM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
Of course, the fuel pump will need to be changed to the high pre. injection pump; perhaps you have that with all the F.I. bits.
ClayPerrine |
Mar 24 2016, 11:59 AM
Of course, the fuel pump will need to be changed to the high pre. injection pump; perhaps you have that with all the F.I. bits. Or just go to FLAPS and purchase an Airtex E8445 or equivalent. New pump for about 110.00, and it makes the same pressure and volume as the 350.00 stock pump. |
RohJay |
Mar 24 2016, 12:04 PM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
I bought a 74 1.8L that has dual Webbers, and it is really a pain starting it in cool weather, and it backfires after releasing the accelerator. I recently bought a "complete fuel injection taken from a running 1975 1.8", and I am interested in knowing if I will have compatibility issues. My desire is to return this car to its stock configuration as a casual driver. Few months ago, I reverted to original L-jet FI on my '75 weber carbed engine: no regrets watsoever. You should not have any issues fitting a '75 J-Jet system on a '74, as long as ALL components are from a working '75 system. If the '75 has smog unit, you can very well ditch that AFAIK. Plenty of resources here to guide you : http://bowlsby.net/914/Classic/TechNotebook.htm. Also this post I made while I was trying to figure my way, might be of use: http://www.914world.com/bbs2/index.php?sho...=260942&hl= Good luck |
cgnj |
Mar 24 2016, 05:08 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Ljet should be able to handle common carb cams. Measures the air going in, so no vacum signature issues.
jcd914 |
Mar 24 2016, 05:37 PM
It does not take much cam to causes too much pulsation in the intake air flow and the air flow meter can't handle it.
jim |
saigon71 |
Mar 24 2016, 06:14 PM
Of course, the fuel pump will need to be changed to the high pre. injection pump; perhaps you have that with all the F.I. bits. Or just go to FLAPS and purchase an Airtex E8445 or equivalent. New pump for about 110.00, and it makes the same pressure and volume as the 350.00 stock pump. (IMG:style_emoticons/default/agree.gif) +1 on the Airtex pump if you need a high pressure pump. Great unit! |
ausDan |
Mar 24 2016, 07:15 PM
I bought a 74 1.8L that has dual Webbers, and it is really a pain starting it in cool weather, and it backfires after releasing the accelerator. I recently bought a "complete fuel injection taken from a running 1975 1.8", and I am interested in knowing if I will have compatibility issues. My desire is to return this car to its stock configuration as a casual driver. I can help and I am in the DFW area. We are doing one for Rob-o in the near future, and you are welcome to join us. Thanks for the response, I am interested in building some knowledge before jumping into it. Great to find someone close by - even at 200 miles. I am still trying to decide how to configure the car. I think I also have some issues with valves as they are noisy. My thought is to rebuild and ditch the carberators for FI. Once the engine is warmed up it runs pretty well and seems like it doesn't burn oil. |
ausDan |
Mar 24 2016, 08:09 PM
I bought a 74 1.8L that has dual Webbers, and it is really a pain starting it in cool weather, and it backfires after releasing the accelerator. I recently bought a "complete fuel injection taken from a running 1975 1.8", and I am interested in knowing if I will have compatibility issues. My desire is to return this car to its stock configuration as a casual driver. The only compatibility issues would be if a non FI camshaft was installed for those carbs. Any idea what camshaft is in your engine? Stock FI is an excellent system for a stockish car. It may take some time to sort it out, but it's worth the effort in my opinion. I don't know, but it feels as though it has a non-stock cam. As I go though it, I want to return it to stock. I think it has some ticking noise coming from the heads I suspect valve wear. I am getting some excellent as well as reassuring posts to this. |
Mar 24 2016, 08:24 PM
A camshaft designed for carbs would have more overlap then a stock camshaft.
This creates flutter inside the plenum which can make the air fuel meter flapper door flutter and give you issues. But, my thoughts A) most people never change the camshafts, they just flipped to carbs B) you can get away with a street camshaft for carbs, there are stronger springs if needed ( a rebuilder can help you, Google 944 afm) C) you won't know till you try, and take the offer of local help, it will save you months of troubleshooting |
ngk007 |
Mar 25 2016, 10:48 AM
Newbie Group: Members Posts: 4 Joined: 14-January 16 From: Sicklerville, NJ Member No.: 19,561 Region Association: North East States |
I bought a 74 1.8L that has dual Webbers, and it is really a pain starting it in cool weather, and it backfires after releasing the accelerator. I recently bought a "complete fuel injection taken from a running 1975 1.8", and I am interested in knowing if I will have compatibility issues. My desire is to return this car to its stock configuration as a casual driver. Hi All, I too am tired of Carb life on my '75 914 2.0 and am looking for a complete Fuel Injection kit, when I purchased my car a year ago, it came with Dellorto carbs and I do not have any of the stock injection parts including electronics. Anyone out there have a full system for sale or from a donor car? |
Bob L. |
Mar 25 2016, 11:12 AM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
First off... (IMG:style_emoticons/default/welcome.png)
There is a small but growing number of us in Austin. We have not gotten together yet but I think we are interested in doing so. I don't know much about L-jet but I can still help out. Where in Austin are you? I am near the Arboretum, others in Georgetown and Pflugerville. LETS GET IT ON! |
ClayPerrine |
Mar 25 2016, 11:14 AM
Betty and I will be in Austin for the PCA club race at COTA. We will be in her 914. How about we arrange a dinner for then?
ausDan |
Mar 25 2016, 12:04 PM
First off... (IMG:style_emoticons/default/welcome.png) There is a small but growing number of us in Austin. We have not gotten together yet but I think we are interested in doing so. I don't know much about L-jet but I can still help out. Where in Austin are you? I am near the Arboretum, others in Georgetown and Pflugerville. LETS GET IT ON! Near Manchaca Road - would like to trade numbers/email. |
ausDan |
Mar 25 2016, 12:16 PM
Betty and I will be in Austin for the PCA club race at COTA. We will be in her 914. How about we arrange a dinner for then? Great, I would like to see if you think the box of L-Jet looks workable. When I bought it they said it came straight from a running car, and the parts are well sealed in plastic bags. Then I took an exploded diagram, and used that to see if anything was missing - I think it's about as complete as I expect. Who knows, I usually have to shop around for something. I am not a well trained mechanic - much less air cooled flat H-4. I have rebuilt one engine, and that was a Ford V6 SOHC (took a few months and a lot of advice and frustration) which at 40K miles still runs. Now I am interested in these air cooled engines. We could meet when you are in town. |
ClayPerrine |
Mar 25 2016, 12:26 PM
Betty and I will be in Austin for the PCA club race at COTA. We will be in her 914. How about we arrange a dinner for then? Great, I would like to see if you think the box of L-Jet looks workable. When I bought it they said it came straight from a running car, and the parts are well sealed in plastic bags. Then I took an exploded diagram, and used that to see if anything was missing - I think it's about as complete as I expect. Who knows, I usually have to shop around for something. I am not a well trained mechanic - much less air cooled flat H-4. I have rebuilt one engine, and that was a Ford V6 SOHC (took a few months and a lot of advice and frustration) which at 40K miles still runs. Now I am interested in these air cooled engines. We could meet when you are in town. Dinner on Friday or Saturday night would be great. But you will have to come to us, because we are working grid for the race, and we are usually wiped out after that. Any other Austin 914 owners want to join us? |
ChrisFoley |
Mar 25 2016, 12:47 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This creates flutter inside the plenum which can make the air fuel meter flapper door flutter and give you issues. Do you know this from experience? My experience is that the AFM is not negatively affected by a fair amount of overlap. It's harder to tune the engine because the programmed fuel curve isn't correct for the performance characteristics of a more aggressive camshaft. Adjustments within the AFM to keep the metered fuel rate correct are limited so additional enrichment may be needed. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:05 AM |
