opening the case, of the engine block |
ben1440 |
Mar 25 2005, 09:39 PM
Member Group: Members Posts: 171 Joined: 1-March 05 From: Santa Rosa Ca Member No.: 3,688 |
I have removed just about everything i can possible take off the block except for what is inside it. I am assuming with all bolts and everything taken off i would basically be prying the block apart but my knowledge is limited. Am i right in trying to pull it apart?
newdeal2 |
Mar 26 2005, 10:23 AM
Unregistered |
There are some "hidden" bolts in the flywheel area in I'm not mistaken but once all bolts are removed it should pry apart with a little effort. Start in the oil pump area and just move around the case carefully.
Lo-Fi Version | Time is now: 12th May 2024 - 05:15 AM |
