ben1440
Mar 25 2005, 09:39 PM
I have removed just about everything i can possible take off the block except for what is inside it. I am assuming with all bolts and everything taken off i would basically be prying the block apart but my knowledge is limited. Am i right in trying to pull it apart?
newdeal2
Mar 26 2005, 10:23 AM
There are some "hidden" bolts in the flywheel area in I'm not mistaken but once all bolts are removed it should pry apart with a little effort. Start in the oil pump area and just move around the case carefully.
