FS 911 2.2 S Motor 700 miles, Fresh just rebuilt, SOLD SOLD SOLD |
toolguy |
Mar 24 2016, 02:19 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
The 914-6 sold and I've got this left. . the Estate authorized a $5K drop to a lower price/ /
SOLD SOLD SOLD. . GOING TO A NEW HOME IN A 911 I just removed this motor from a 914-6 in which I reinstalled its original motor. . It has less than 800 miles on it after a professional shop rebuild. This is a proper 1970 2.2 S motor. . All the engine work was done by Mark Kenninger / Black Forest San Diego whose personal 911SC took TTOD at the Parade. This is another of his exceptionally fine running motors. The list of work includes magnafluxed crank, resurface of case halves and a line bore. New case savers installed. Has new S cams using 1975 Carrara 36 mm big port heads. This motor is set up for Webbers. It now has pressure fed tensioners, and a full valve job with all new valve guides and seals. All rods rebuilt and balanced, all bearings new including #8. Everything you'd expect to be renewed was done. Sold as pictured with correct S distributor and matched port carburetor manifolds. Attached image(s) |
rhodyguy |
Apr 9 2016, 09:16 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What can you get for $20k Rick?
Lo-Fi Version | Time is now: 18th May 2024 - 07:53 AM |
