FS 911 2.2 S Motor 700 miles, Fresh just rebuilt, SOLD SOLD SOLD |
toolguy |
Mar 24 2016, 02:19 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
The 914-6 sold and I've got this left. . the Estate authorized a $5K drop to a lower price/ /
SOLD SOLD SOLD. . GOING TO A NEW HOME IN A 911 I just removed this motor from a 914-6 in which I reinstalled its original motor. . It has less than 800 miles on it after a professional shop rebuild. This is a proper 1970 2.2 S motor. . All the engine work was done by Mark Kenninger / Black Forest San Diego whose personal 911SC took TTOD at the Parade. This is another of his exceptionally fine running motors. The list of work includes magnafluxed crank, resurface of case halves and a line bore. New case savers installed. Has new S cams using 1975 Carrara 36 mm big port heads. This motor is set up for Webbers. It now has pressure fed tensioners, and a full valve job with all new valve guides and seals. All rods rebuilt and balanced, all bearings new including #8. Everything you'd expect to be renewed was done. Sold as pictured with correct S distributor and matched port carburetor manifolds. Attached image(s) |
rhodyguy |
Apr 9 2016, 09:16 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What can you get for $20k Rick?
rick 918-S |
Apr 9 2016, 11:41 AM
Hey nice rack! -Celette Group: Members Posts: 20,468 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What can you get for $20k Rick? I guess my point is if your doing a conversion why would you want a small displacement engine for 20k when you can get so much more for the money. But as long as you asked... 2.4S R7 case asking 9,900.00 http://www.ebay.com/itm/Porsche-911-engine...wAI&vxp=mtr (IMG:style_emoticons/default/smile.gif) Small displacement 69 2.0 S spec fresh $ 9,900.00 http://www.ebay.com/itm/Porsche-911-engine...wAI&vxp=mtr Ok, that's two engines for the price of one Here's a complete 2.7S spec with CIS. $ 7,000.00 http://www.ebay.com/itm/Porsche-911-1977-2...HQA&vxp=mtr My second point is there have been engines posted on the early 911 registry for "the moon prices." In fact I know of one that was listed there after guy's commented on the engine being worth sooo much money and in demand. The only response to the ad was from some low baller early 911 guys. Maybe trying to get it for the real price. The guy ended up just using the engine. The price may be good if you can reunite the engine with the car. You asked. |
Lo-Fi Version | Time is now: 24th May 2024 - 06:23 PM |
