fi harness, correct plug-in side |
martinef1963 |
Mar 26 2005, 09:50 AM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
have a quick qestion. was putting my harness back and was wondering - how could I tell if i was putting the mps/fi injectors/tps...etc....
is there a right/wrong side.... |
Mueller |
Mar 26 2005, 09:55 AM
you "should" be able to only install them one direction, but that is not always the case...for the injectors, does not matter, for the other devices, you have to match up the numbers on the connectors, they'll be there, just hard to read sometimes....
Bruce Allert |
Mar 26 2005, 12:12 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Hmmmmm (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
I wonder if that could be part of my problem. Some of the connectors are sharply cornered on one side and the opposite corners are rounded. Trying to see if the female connector is in the same configuration is sometimes quite hard. I'll try finding numbers & see if that works...... .........b |
JeffBowlsby |
Mar 26 2005, 02:34 PM
914 Wiring Harnesses Group: Members Posts: 8,502 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
For D-Jet cars all the harness connectors can be put in either way and it does not matter except:
ECU plug TPS TS1 (intake air temp) Dizzy The 4 pole plug onto the relay plate. These exceptions have 'sexed' plugs and they can only be inserted the correct way. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Rhodes71/914 |
Mar 26 2005, 02:47 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
What about the MPS isn't it a one way only plug as well?
JeffBowlsby |
Mar 26 2005, 03:21 PM
Nope...the inner two are one coil, the outer two the other coil. If it fits, its right.
Rhodes71/914 |
Mar 26 2005, 03:30 PM
Oh, cool. |
wilchek |
Mar 26 2005, 04:24 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
For the MPS, If you pull back the rubber boot you will see that the wires are number that match the number on the MPS. As least on my 73 2.0 they were. I was kind of surprised to see the wires marked. Does anyone else know if the wires in the rest of the car are marked at all with numbers.
jwalters |
Mar 26 2005, 05:04 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Yo nando--check your other tps--see if it is a fiver--ifn it is, switch em out and use your new fi stuff...that is if you have one--I thought you do--I got your messege, tried calling you a little while ago--J
martinef1963 |
Mar 30 2005, 04:20 PM
Okay - now another question (or two): I bought a spare d-jet FI complete only to find out that the original FI harness is a 5-pole, but the spare that I wanted to switch w/ is only a 4-pole.
what is the difference and what will happen if I install the 4-pole into my current 5-pole TPS? thanks, another question - does anyone have a good 4-pole TPS for sale? thanks again (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
bd1308 |
Mar 30 2005, 04:40 PM
yup....ive got one. pm me. never opened, still in box. never used.
JeffBowlsby |
Mar 30 2005, 07:37 PM
Nothing, if you install it correctly. Both FI harnesses have only 4 wires for the TPS. The 5 pole variety only has 4 wires in it if you will look (1 cavity is empty). The trick is to get the 4 pole plug in the 5 pole TPS correctly and there are only 2 ways that can work. One of them will be correct. The 5 pole TPS has the wire numbers on it too so you can match them up that way with the wire numbers on the harness. Or bestter yet...just use the 4 pole TPS...like he said.. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 12:40 PM |
