OT: Top Fuel Dragster Info. incredible if true!, just got this via email... |
Bruce Allert |
Mar 26 2005, 12:33 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Interesting Facts about a Top Fuel dragster
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500. * Under full throttle, a dragster engine consumes 1-1/2 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced. * A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger. * With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle. * At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture for nitromethane the flame front temperature measures 7050 degrees F. * Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases. * Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder. * Spark plug electrodes are totally consumed during a pass. After ½ way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow. * If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half. * In order to exceed 300 mph in 4.5 seconds dragsters must accelerate an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's. * Dragsters reach over 300 miles per hour before you have completed reading this sentence. * Top Fuel Engines turn approximately 540 revolutions from light to light! * Including the burnout the engine must only survive 900 revolutions under load. * The redline is actually quite high at 9500rpm. * The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph. (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta). Putting all of this into perspective: You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course. That folks, is acceleration (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) .......b |
TJB/914 |
Mar 26 2005, 01:03 PM
Mid-Engn. Group: Members Posts: 4,326 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Hey Bruce,
Dragsters have come a long way since my Dragster days in the early 60's. Here's the "B" Gas 389 Pontiac Powered K-88 Chassis Research we built & drove back then. My best time was low 10's & high 140's MPH. That's my old friend Bob driving at the Indianapolis Nationals in early 60's. There were only (2) b-Gas dragsters that year so we were up for top B-Gas eliminations. We lost. That Dragster was built with all used parts and cost about $500 bucks. Can't do that today. Tom Good old days. Attached thumbnail(s) |
cdmcse |
Mar 26 2005, 01:42 PM
Member Group: Members Posts: 340 Joined: 17-December 04 From: Georgetown, Ky Member No.: 3,305 |
Just curious, where there ever any professional Porsche dragsters or engines?
Type 4 |
Mar 26 2005, 02:07 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
I love the smell of Nitro in the morning
TimT |
Mar 26 2005, 02:14 PM
Eddie Bello used to dragrace a twin turbo 993, I believe times were in the 8-9 second range
URY914 |
Mar 26 2005, 02:50 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,483 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I think there was a -6 rail I saw pictures of once.
URY914 |
Mar 26 2005, 03:01 PM
I just found the picture in my "Porsche Specials" book. No story on it just a picture. I'd say mid-late '60's . It had a rear engine and a full body, The caption on the picture says "Dragster: One of the many Porsche-powered American dragsters." Really... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Brett W |
Mar 26 2005, 03:44 PM
Didn't Eddie have a little run in with the law? I heard that is what took him away from racing for a few years.
He was really quick from what I remember. |
Lo-Fi Version | Time is now: 10th May 2024 - 12:35 AM |
