Riverias, Mix match |
14Maschine |
Mar 26 2005, 01:16 PM
Newbie Group: Members Posts: 48 Joined: 18-November 04 From: Pleasanton, CA Member No.: 3,137 |
What is the deal with my rims? I wonder if anyone can tell me if its a different year or just a knock off.
14Maschine |
The others
bernbomb914 |
Mar 26 2005, 01:28 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I have two sets one of each and have been told that the offsets are differant and the one with the rolled edge is for VWs. I would not say that is cast in stone but that is what I was told
Bernie |
rhodyguy |
Mar 26 2005, 01:46 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
is the backspacing and offset the same on both styles? if you like the look of rivs find a pair to match the ones with the backspacing of around 4 1/2" iirc. few things are worse than a tire shop that puts hammer on weights on the outside of a rim. they can get the balancing right with the weights on the back side if they bother and you specificly tell them to.
k |
9144guy |
Mar 26 2005, 02:40 PM
Member Group: Members Posts: 253 Joined: 26-February 05 From: tulsa,ok Member No.: 3,672 |
HERES A PIC OF MINE
rhodyguy |
Mar 26 2005, 02:46 PM
the outside lip on yours is like shaped like the form-vees. i bet you can run wider tires with no problem. the extra little step on the outside in one of the other pictues is a dead give away. fake 4-lug fuch have that same step too.
k |
Lo-Fi Version | Time is now: 13th May 2024 - 05:20 AM |
