My First 914 & 2nd Porsche In a Month! |
Apr 2 2016, 03:53 PM
Custom Member Group: Members Posts: 24,569 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It's the other side you need to show.....
TM_Corey |
Apr 2 2016, 03:56 PM
Member Group: Members Posts: 231 Joined: 28-March 16 From: Indianapolis Member No.: 19,809 Region Association: Upper MidWest |
TM_Corey |
Apr 2 2016, 04:55 PM
TM_Corey |
Apr 3 2016, 09:21 AM
Passenger side rockers and hell hole.
TM_Corey |
Apr 3 2016, 09:23 AM
I have an appointment with a place in Indianapolis next week that has done several vintage 911, 912 and 914 restorations.
Probably going to start with just the body work and paint and then recoup some cash and decide what I want to do with the motor. I hate to use anything except the original motor considering how original the car is. |
EdwardBlume |
Apr 3 2016, 09:32 AM
You're smart to go after the body. Looks like these some work to do. Good luck!
TM_Corey |
Apr 18 2016, 07:03 PM
Well it has begun! Decided to go mechanical instead of body work first. I plan to drive it this summer and then start the body work this winter.
It's in the shop, this week will be: New Fuel Lines New Fuel Filter Clean Fuel Tank "New" rebuilt Fuel Pump Clean Injectors New Vacuums lines Replace points with Pertronix New Bosch Blue Coil New Plugs New Plug Wires New Cap & Rotor New Master Cylinder New Brake Hoses Rebuid The Calipers Repack front wheel bearings New Front wheel seals Turn or Replace all 4 Rotors Replace CV axle boots Clean & Repack CV Joints Replace Pushrod Return Tubes Adjust Valves New Valve Cover Gasket Replace Oil Cooler Seals Replace Sump Cover Seal Oil Change & Filter New Battery Repaint Original Wheels New Tires (195/60/15) |
TM_Corey |
Apr 18 2016, 07:23 PM
Nice '74 and great color. It looks like the tach might be original but the other two gauges have been replaced with the earlier silver disk type. BTW....you'll probably have to sell the 997 to help pay for the rust repairs (IMG:style_emoticons/default/smile.gif) According to the owner (and the warranty receipt), the tach is the one that was replaced due to "not working when cold". He says the other gauges were in it when he bought it. I have the original warranty receipt. |
Mike Bellis |
Apr 18 2016, 08:07 PM
That's a California parts car... (IMG:style_emoticons/default/poke.gif)
My guess is they use salt on the roads in winter? |
TM_Corey |
May 24 2016, 11:39 AM
Some update pics!!
Decided to also do new motor mounts, sand blast and paint all the motor pieces, and crack the motor and replace the gaskets and rings. Haven't decided on the cam and lifters, going to see what they look like. Attached image(s) |
TM_Corey |
May 24 2016, 11:45 AM
Another
Attached thumbnail(s) |
TM_Corey |
May 24 2016, 11:52 AM
Another
TM_Corey |
May 24 2016, 11:54 AM
Another another
TM_Corey |
May 24 2016, 11:57 AM
Last one for now
TM_Corey |
Sep 28 2016, 01:25 PM
Some Updates!
TM_Corey |
Sep 28 2016, 01:27 PM
All four calipers rebuilt.
TM_Corey |
Sep 28 2016, 01:32 PM
Hell hole repairs!
TM_Corey |
Sep 28 2016, 01:33 PM
Before
TM_Corey |
Sep 28 2016, 01:43 PM
After:
Attached thumbnail(s) Attached image(s) |
billh1963 |
Sep 28 2016, 02:26 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Very nice! When will you be back on the road?
Lo-Fi Version | Time is now: 29th April 2024 - 11:00 AM |
