DOH! Check your tranny mounts, egads! |
TravisNeff |
Mar 26 2005, 05:16 PM
first gear and reverse likes to pop out of gear, went to adust the clutch cable as it was pretty far off. Just as I am getting ready to come out from under the car, what's this?? missing bolt on the transmission mount. Good thing I caught that, it was hanging down 1/2 at the front. Might as well check others. ALL 3 other bolts were hand tight. Whew! that could have been a little scary dragging ass all over town.
But things be as they may, I glance up towards the front wheels and I see brake fluid on the tire. Looks like I stripped out the hardline off the caliper to the flex line. Good thing I caught that too... |
blk'72 |
Mar 26 2005, 05:18 PM
Member Group: Members Posts: 83 Joined: 2-November 04 From: Pleasanton, CA Member No.: 3,053 |
Damn... I think i should check also...how do you do it, where do youlook for that?do you need to jack up the car?
Good thing you caught it! R. |
TravisNeff |
Mar 26 2005, 05:21 PM
Yep, jack up the rear and secure with jackstands. You will see the ears of the transmission just ahead of your muffler. 1 big assed bolt secures the trans mount to the transmission, 2 13mm bolts secure the mount to the body. While you are under there give everything the once over!
Rhodes71/914 |
Mar 26 2005, 05:34 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
I don't feel right if I don't have my car on jack stands at least a couple of times a week.
Always pays to check things over once in a while with 30+ year old cars. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
tat2dphreak |
Mar 26 2005, 07:14 PM
sometimes I just lay under my car and look for something that "doesn't look right" I've fixed a lot of little things like that!
Lo-Fi Version | Time is now: 12th May 2024 - 04:03 AM |
