1.7-4 engine help |
1.7-4 engine help |
FastFroggy |
Mar 30 2016, 05:42 PM
Newbie Group: Members Posts: 42 Joined: 27-November 15 From: Ann Arbor MI Member No.: 19,415 Region Association: Upper MidWest |
I ran into a problem last weekend. Finally able to get some highway running last weekend. Unfortunately on a high speed run i suddenly got a plume of oil smoke.
I will be investigating in more detail this coming weekend, but appreciate any recommendation on what to check. I plan to inspect head cover gasket and oil filter & oil. Here are a few notes I made: a. I think the smoke started after I lifted off throttle. b. head cover gasket appears to have failed again ( replaced only 15-30 miles ago) c. I am running Webber Carbs, header exhaust and unknown 1.7l cam/piston set. d. Oil pressure was maintained at all times ( Accusump shows 40psi- idle pressure) e. I have an crankcase breather hose from the OE filler neck to a separator about 6-8inches over the filler to catch-can about height of OE filler neck. f. I do not like the color of oil on the inner oil cap. ( looks a little milky ). If it was a water-cooled engine I would say head gasket. g.underneath is coated with oil on driver side. Thanks |
ChrisFoley |
Mar 31 2016, 02:44 PM
I am Tangerine Racing Group: Members Posts: 7,919 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
A drip from a leaking valve cover gasket onto a header will make a pretty good smoke cloud.
FastFroggy |
Apr 2 2016, 05:37 PM
It looks like I sucked the driver side cam cover gasket AGAIN!!!! Which is of course the reason for the smoke. What I was trying to figure out is why the passenger side twice in less than 20 miles.
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-19415-1459640274.1.jpg) What I know now: a. found a small spot of porosity on the weakest width of gasket interface, where the gasket got sucked in. (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-19415-1459640275.2.jpg) b. the FelPro gasket I put in last time was a but long for the cover length. May have contributed to issue. (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-19415-1459640275.3.jpg) PN 021 101 481 fit much better. (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-19415-1459640275.4.jpg) c. the left and right cam covers are different. driver side with 2 inner tabs and the passenger side with 6 inner tabs. Passenger side has not leaked yet. (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-19415-1459640275.5.jpg) Now the questions where can I get a passenger side cam cover with 6 tabs? and does this make sense as a fix or do I need to keep digging? |
Geezer914 |
Apr 9 2016, 09:55 AM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Get out the welder (IMG:style_emoticons/default/welder.gif) and make the tabs out of sheet metal. Drill a hole in each one so you can spot weld them to the inside of the valve cover.
ThePaintedMan |
Apr 9 2016, 11:40 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Or you can do this one:
http://www.pelicanparts.com/techarticles/9...alve_covers.htm I did it, ran my car at multiple autocrosses and track events and have not had a single issue with the valve covers. Basically just weld in a strip all the way around the inside of the valve cover to hold that gasket in place. |
Wyvern |
Apr 9 2016, 01:29 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I used the red silicone, lil bit thicker gaskets from 914rubber . ... No Mas leaky
FastFroggy |
Apr 10 2016, 05:50 AM
Thanks
has anyone tried EMPI breather kit to the valve covers? |
Randal |
Apr 11 2016, 01:28 PM
Thanks has anyone tried EMPI breather kit to the valve covers? I didn't use an EMPI, but bought a bigger one and had no further issues. My first time on the track with a smaller breather produced an oil filled engine compartment. And I did have tubes running from the valve covers to the breather, which was mounted as high as possible. Secondly, for all those having trouble with gaskets, the sure way to fix is to weld in a strip and then use the high temperature gasket material. You won't have any other issues. (IMG:style_emoticons/default/smile.gif) |
FastFroggy |
Apr 11 2016, 06:15 PM
Many thanks for the insight. time to get welding.... (IMG:style_emoticons/default/welder.gif)
for a couple of tack welds. |
Randal |
Apr 12 2016, 11:55 AM
Many thanks for the insight. time to get welding.... (IMG:style_emoticons/default/welder.gif) for a couple of tack welds. Suggest you keep the material for the strip as thin as possible, as all it's doing is holding the gasket in place. With aftermarket Pauter rockers, I had to remove some additional material, from the strip, as I did get minor rubbing. |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:02 PM |
